Any one replace their lower ball joints?
Old Sep 5, 2010 | 10:38 AM
  #76
nogoodname's Avatar
I'll have a look at it today.
Also, I have another noise coming from the rear. It's a pretty bad metal on metal clanking sound when going over bumps.
Old Oct 5, 2010 | 08:14 PM
  #77
blAk mAx's Avatar
ordered the set of 2 for $60 the other day..now i find this :
http://cgi.ebay.com/ebaymotors/1-Fro...Q5fAccessories
Old Oct 12, 2010 | 01:54 AM
  #78
SAM45G35's Avatar
I need to replace my ball joints as well...are the ebay ones pretty good? whats the dif. between those and OEM?
Old Oct 26, 2010 | 05:09 PM
  #79
fatlip's Avatar
So these are the lower ball joints at the knuckle? Whats the difference from the other ball joints on ebay? Looks like those have a zerk fitting on them and the others dont. Has anyone confirmed if they would fit an 03 g35 coupe?
Old Oct 28, 2010 | 11:48 PM
  #80
blAk mAx's Avatar
replaced my driver side today
Old Nov 17, 2010 | 09:32 PM
  #81
nlallen141's Avatar
I've ordered the ebay joints, as well as "Whiteline Plus Urethane Front Lower Inner/Outer Control Arm/Shock Mount Bushings 2002-2008 350Z/2003-2006 G35 Coupe " from z1. I'm going to try to install on an awd setup, ill post confirmation if everything works.
Old Nov 21, 2010 | 09:14 AM
  #82
blAk mAx's Avatar
Should I post a step by step on install?
Old Nov 21, 2010 | 11:17 AM
  #83
datbeans's Avatar
please do
i will love you long time
Old Nov 21, 2010 | 05:32 PM
  #84
blAk mAx's Avatar
replaced my ball joint , here are some pix and how to vids:
tools you`ll need:
floor jack & jack stands
needle nose pliers
ball joint press (rent from autozone & advanced auto parts for $100)
ratchet or breaker bar..i think a 19 socket
may need ball joint separater
remove snap ring with needle nose :
unscrew top of balljoint and use jack to lift and separate control arm
use the balljoint separator to remove
how it looks on new ball joint:
out with the old
in with the new
good videos to use as reference :
http://www.ehow.com/video_4401497_re...ng-trucks.html
http://www.ehow.com/video_4401498_pr...all-joint.html
http://www.ehow.com/video_4401499_in...all-joint.html
http://www.ehow.com/video_4401500_pr...all-joint.html
Old Jan 13, 2011 | 05:22 AM
  #85
JBF's Avatar
JBF
bump.
how are they holding up?
Old Feb 1, 2011 | 06:08 PM
  #86
JBF's Avatar
JBF
wow...
I pressed mine in and they are too long...by almost 7mm.
and now my OEM ones are trashed
Old Feb 1, 2011 | 06:32 PM
  #87
blAk mAx's Avatar
where did you buy them? is the balljoint pressed all the way down?
Old Feb 1, 2011 | 07:17 PM
  #88
JBF's Avatar
JBF
the shafts are too long. I ended up getting a spring washer and a flat washer and its good to go.
btw.
how did you get the bottom of the dust boot to seat?
Old Feb 1, 2011 | 08:04 PM
  #89
blAk mAx's Avatar
i just set it in place, put the control arm back, then tightened the caste nut
Old Feb 2, 2011 | 12:41 AM
  #90
ttrank's Avatar
Grocery getter
My ebay ones were not too long.
You have already rated this thread Rating: Thread Rating: 4 votes, 5.00 average.
