Questions about Air Ride suspension ask here
Old Mar 15, 2012 | 05:59 PM
  #316
cturnbull802's Avatar
Originally Posted by kennymo
no the 4'' is for the upper cups. when you buy cups they come in a set. the tops will most likely be 4'' and the lowers will be 2''
thanks for the quick reply, the reason i asked for clarification is the link you have on page 2 gives you a set of (4) and you pick the size
http://www.avsontheweb.com/product.p...&cat=35&page=1
Old Mar 19, 2012 | 02:22 PM
  #317
bur13arry's Avatar
OE struts
Does anyone know what are the lengths of the OE struts (front/back)? I'm trying to piece a kit together and looking at the Air Lift Universal Struts.
They said they need to know the length of the OE struts in order to recommend which universal air struts would do the job
Old Mar 19, 2012 | 02:44 PM
  #318
i dont think air struts would work in the rear.... possibly for the front, why not just go bag over oem strut? like whats in the 2nd post in this thread?
also the rear shock limits travel and need to be replaced with some that are shorter to get low.
Old Mar 26, 2012 | 09:06 PM
  #319
G35pm's Avatar
how old are the bags that you are talking about? 1-1.5mm is REALLY small and i would not be worried about it. the bags i have on my current project look like **** and have tons of those 1-1.5 cracks in them. its normal and unless they start getting big or the bag starts leaking i would not worry about it.
Bags are probably about 18months old, only on the car for year. Thanks for the response man!
Old Apr 10, 2012 | 06:22 PM
  #320
He-man's Avatar
good price or not
all brand new parts + installation for 2450
warranty as long as you own your car except the compressor.
adjust all 4 corners at the same time or indiviual
reuse front oem shocks only, everything else will be repace
if you guys know anywhere in socal charge cheap, lmk, thanks
Old May 5, 2012 | 12:27 AM
  #321
CHAMUKO's Avatar
About the shocks in the rear ..... Do u happen to know Wat kind of shocks would work to be prtty much on the floor ??? I have bags in my car in the rear but Like u said the shock bottoms out
Old May 5, 2012 | 10:58 PM
  #323
kennymo's Avatar
yea you can do it a couple of ways. either use smaller valves or the easiest/cheapest way is to get some ball valves from your local hardware store. put them between the fill valves and the bags. only have the ball valve open as much as you want it to be. more open = faster
Old May 6, 2012 | 05:11 PM
  #325
bigc's Avatar
Wings Nation
^ what size lines are you running Homie? i had 1/2" before (all i could get at the time), but swapped out to 1/4" a few months back. The system is WAY more controllable now.
Old May 6, 2012 | 10:35 PM
  #327
bigc's Avatar
Wings Nation
^ will see what I can do, but don't hold your breath. the only vid cam I have is my cell phone and its not very good
Old May 9, 2012 | 06:38 PM
  #328
YOUNG1TRAN's Avatar
so guys i got a quick question. i have a ver very very very slow leak out of my air tank, 1psi every . first of i checked eeverywhere with soapy water.. no result. so i ended up pulling my leader hose out n noticed that it has a bad check valve. my question is could the bad check valve cause the air to push back out of the compressor? will getting a new leader hose with check valve solve my super duper slow leak? thanks!!!
Old May 9, 2012 | 06:40 PM
  #329
YOUNG1TRAN's Avatar
btw amateuRN, 1/4 air line/ fittings are very smooth going up.
You have already rated this thread Rating: Thread Rating: 3 votes, 4.33 average.
