Pirates coilovers
Old Jul 3, 2011 | 02:02 AM
  #151
Deemo's Avatar
well there is tony everybody!
that man knows everything about those MDU coils.
Old Jul 3, 2011 | 08:28 AM
  #152
chatt350gt's Avatar
ok i think ill set up true coil style today but i have 1 more question..when i remove the bottom to slide the spring in wont the spring be sitting metal to metal against the rear top? wont that cause issues?
Old Jul 3, 2011 | 09:13 AM
  #153
NFSP G35's Avatar
? = 2B || !2B
Thanks Tony
Old Jul 3, 2011 | 02:00 PM
  #154
twalls's Avatar
CLUB MODERATOR
Nah... it won't.. you see the plate holds it in place on the top, and the interlocking rings hold it in place on the bottom (Get the 2 interlocking rings from the spring pillar that you'd use to hold it in the boot), make sure the springs are in nice and snug, and you have no issues.. Use the little black rubber on top of the interlocking ring, and where the spring touches the plate and you get no rattle.. Now it's not metal on metal..
(picture courtesy of ebay.. hahahahaah)
Old Jul 3, 2011 | 03:18 PM
  #155
toro12's Avatar
20 Year Member
Yarr, true coilovers you'll enjoy that.
Chatt350gt, well done on the install and write up, matee.
Sounds as though you got good support here on your questions yesterday.
I'm gonna convert my OEM rear struts to true soon too!
Old Jul 3, 2011 | 03:50 PM
  #156
twalls's Avatar
CLUB MODERATOR
OEM vs True is Night and day w/ the bounciness of the rear.. I couldn't take OEM either.. Tried OEM, because you CAN go lower on the oem setup.. but I'm plenty low on the true coil setup..
you're limited w/ how low you can go in true coil setup (not by much) because eventually you'll start compressing the strut.. You don't want to compress the strut because that's what takes the "shock" when you hit a bump.. You want the strut to be not affected during normal driving and you ride on the spring.. The strut should only be engaged in big bumps or "shocks" to the suspension and the gas/liquid w/in the strut straightens everything back out to it's set ride height.
When you convert to True coil setup, you're in essence putting everything on one assembly rather than having them as individuals.. Where as you were previously able to set the compression of the spring independently of the strut, now you have to be conscious of how much you compress the spring because you DO NOT want to be riding on a compressed strut.. You WILL BOTTOM OUT on bumps.. NO BUENO!!! Lol..
Old Jul 4, 2011 | 12:33 AM
  #157
chatt350gt's Avatar
yeah might be giving up on this plan...going to do some adjusting tomorrow to raise it up a little but right now i just hit the front mud guards and just about got stuck on a speed bump and felt like i tore the whole undercarriage out...
Old Jul 4, 2011 | 12:40 AM
  #158
twalls's Avatar
CLUB MODERATOR
went too low.. definitely need to raise it up bro..
Old Jul 4, 2011 | 12:53 AM
  #159
4D05G35's Avatar
Looks like this is what I will be doing this week.
Old Jul 4, 2011 | 03:22 AM
  #160
toro12's Avatar
20 Year Member
Get 5" clear under your rocker panels next body height adjustment.
Old Jul 4, 2011 | 03:28 AM
  #161
twalls's Avatar
CLUB MODERATOR
I'm 3.5" off the ground.. I just completely avoid all speed bumps, and if I HAVE to go over them, ANGLES ARE YOUR FRIEND!!!
Old Jul 4, 2011 | 03:56 AM
  #162
toro12's Avatar
20 Year Member
Narrr, hope the belly is Ok, but ye "private shame" is showin' matee now that ye crashed on the horizon! Not just you but others ere have run aground.
I be to goin to 5" at the rockers next port of call.
Low riding can suck in the real world to a blind drivin' dork, see this new thread of repenting G-squiddies from all over the land.
It surprised me too.
https://g35driver.com/forums/g35-sed...w-sucks-2.html
Old Jul 4, 2011 | 03:15 PM
  #163
chatt350gt's Avatar
im used to driving low even before the G35 but a low G35 is different just cause of the wheel base on the coupe..i could get around in my DSM after mastering it but now the issue is i have my little brother living with me and hes 300lbs so the added weight topped it off..once he gets a car itll be back to being lower..i adjusted it today like a half inch higher to see if it helps..i realize i didnt hit the undercarriage but the rear portion of the exhaust that hangs down..ill update on how it goes later this week..stiffened up the front and rear to help this issue too. but once i work these things out they'll be no issues..these things are good to go! so if your on the brink of buying them GET THEM already! lol
my apt complex decided to go speed bump happy so i have no choice lol
Old Jul 4, 2011 | 05:03 PM
  #164
toro12's Avatar
20 Year Member
Just like the wifee, ask him to get out at speed bumps.
Just kiddin because you really need to ask him to meet you and the G at the exit of the apt complex.Yeh, your bro drops the passenger side about 3/8" when on board. Truth
Old Jul 4, 2011 | 08:39 PM
  #165
4D05G35's Avatar
lol.
Reminds me of this Accord I used to see often when I was growing up.
It was a late 80's (89-91) accord and the guy was probably 400lbs +. The drivers side of the car was lower than the passenger side by a large margin. Even parked you could see the lean.
But I digress. I think that I will still be swapping to "true coilovers" this week, but I am holding of on lowering the car more. I just purchased new front tires (225/35 vs the 245/35 I have now) and I am shopping for new rear tires (255/30/20 vs the 255/35) before I do anymore lowering.
Side note I will have a set of 245/35/20 and 255/35/20 Nitto 555 for sale soon. less than 2k miles.
