Steering wheel spins freely
Old Aug 26, 2019 | 11:24 AM
R_Rod's Avatar
G35 coupe 6mt
The other night I was driving home and while going around a turn I kind of felt a pop and the steering got very loose. It’s almost like I have super power steering now. Or if you were to turn the wheel with the front jacked up. There’s no resistance. Both tires move like they are supposed to and there’s no noises. When parked you can feel normal resistance but while driving it’s like an arcade game steering wheel. No play or wiggle on the wheels when I jacked it up. Guessing it’s the rack and pinion? No tears, leaks or burning smell which is what google identified as a bad rack. I’ve never had an issue with a steering rack in my life so I’m lost here. Guess I should add it’s an 06 coupe 6mt with that stupid rear active steering stuff. 124k miles.
Old Aug 27, 2019 | 02:11 AM
Scorpi0's Avatar
Congratulations!! You've unlocked Super Power Steering Mode!
Old Aug 27, 2019 | 07:27 AM
R_Rod's Avatar
G35 coupe 6mt
Cool, thanks for the help.
Old Aug 27, 2019 | 05:02 PM
Scorpi0's Avatar
No problem. Its what we're here for.
Old Aug 27, 2019 | 07:03 PM
R_Rod's Avatar
G35 coupe 6mt
Now I remember why I quit looking at forums. Someone feel free to delete this thread. I’m out.
Old Aug 27, 2019 | 10:22 PM
eazdaskeez's Avatar
Yikes. That's some pretty thin skin ya got there buddy. Hopefully someone knowledgeable will reply but wait you asked them to close the thread so maybe not?? 🤔
Old Oct 5, 2019 | 09:36 AM
Babyblue35's Avatar
2005 3.2liter v6 g35coupe
Clock spring
You probably broke the clock spring find another g 35 so and years and replace the clock spring have someone knowing what there doing with a scanner tool so they can reset your traction and r seat your steering angle be care when you take off the bolts in the steering wheel you can strip them eazy
Old Oct 5, 2019 | 01:20 PM
cleric670's Avatar
BANNED!!!
Coupe 6MT Premium RAS
He said the steering "got really easy to turn suddenly". This is usually a failure on the R&P unit itself, there is an adjustment screw that you use to set the pinion preload when you rebuild the units and you can adjust them with a big hex screw on the side of the unit. You can always try tightening up that screw 1/4 turn to see if it helps but I'm guessing one of the little "teeth" on the inside of it broke off and is sitting in the bottom of the unit.
Old Oct 6, 2019 | 08:29 AM
Babyblue35's Avatar
He said no visual damge underneath i check the clock spring make sure you get the right one plus it's not all of the sudden it stuck like that i did the some thing. Does your horn work by chance
winkoftherabbit
Nov 21, 2009 02:16 PM
Grevving6
Aug 2, 2009 04:03 PM
DrewQ1
May 11, 2009 03:40 PM
g35panama
Jun 14, 2008 02:34 AM
