Sway Bar Summary!
Rating: Thread Rating: 4 votes, 4.75 average.
Old Feb 25, 2009 | 08:28 PM
  #301
bigc's Avatar
Wings Nation
General consensus: Upgrade from your stock sways.
Stillens: Yes, they are popular. Its a matter of personal preference and how much adjustability you want.
'06 Endlinks: Haven't heard of anyone having trouble with the beefier '05+ endlinks.
Old Mar 19, 2009 | 02:11 PM
  #302
Mr_pharmD's Avatar
hows the 05 sports package sways compared to the stillen? Anyone also no the thickness of the sports package sways?
Old Mar 19, 2009 | 02:44 PM
  #303
infinus's Avatar
Didn't measure but the stillen sways felt much better than the sport package sways.
Old Mar 19, 2009 | 02:46 PM
  #304
Texasscout's Avatar
Originally Posted by post#1
Stillen:
Construction: 1 3/8-inch diameter (front) and 7/8-inch diameter (rear) tube bars
Bushings: None included (re-use OEM bushings or buy aftermarket ones)*
Stiffness settings for the front/rear sways: from 7% to 70% stiffer than stock
Approximate Price: ~$275
Pros/Cons/Experiences/Settings: Excellent construction, excellent packaging & instructions, reasonable price, no noise. No cons. kenchan drives on Front soft / Rear med. tgenius drives Front med/ Rear med for his sedan.
It would seem that the Stillens are the same O.D. but are "thicker" to get better roll stiffness.
Old Mar 20, 2009 | 01:00 PM
  #305
adamhoud's Avatar
Hmm...I am wondering now if it is worth it to go to the stillen sways if I already have an 06 sport susp.
Old Mar 21, 2009 | 08:49 AM
  #306
Texasscout's Avatar
Yes it would...
Old Apr 2, 2009 | 09:03 AM
  #307
JSNM's Avatar
Wow,im glad i read through these pages,some great info in here!
Old Apr 3, 2009 | 09:39 PM
  #308
Swivel's Avatar
Moderator
Okay, silly question: are the 350evo sways the same for sedan as coupe? I sent them an e-mail but don't expect to hear back until at least Monday.
Old May 14, 2009 | 11:19 AM
  #309
Swivel's Avatar
Moderator
Bump for anyone with 350evo sways on a sedan?
Old May 14, 2009 | 04:14 PM
  #310
Jeff92se's Avatar
Red Card Crew
I would assume. I don't even see 350evo even mentioning the G on their swarbar specs. But as far as I know, Z/G swaybars are interchangable. That includes coupe/sedan
Old Jun 3, 2009 | 03:21 PM
  #311
byte_me77's Avatar
Anyone run Whiteline sways? they are $399 for the set on the Z forum.
Solid Swaybars
Front Swaybar 32mm-h/duty Blade adjustable 2 way.
Rear Swaybar 20mm-h/duty Blade adjustable 3 way.
No idea on stiffness.
Old Jun 3, 2009 | 03:40 PM
  #312
keff108's Avatar
I dont feel like reading through this whole thread to find the advice im looking forbut which sway bars are going to be stronger and last a while without breaking. I like driving backroads so these will help alot. I was thinking either Stillen or Hotchkis. I am leaning heavily toward Hotchkis tho. Any advice?
Old Jun 24, 2009 | 10:31 PM
  #313
DRA-G35-ON's Avatar
Damn I just read this whole thread. Good write up, lots of info... I'll prob choose between Hotchkis & Stillen. Seems like the only complaint about the Hotchkis was the no collar, which is not an issue anymore. The only complaint about the Stillen is you'd have to use stock bushings or buy some... I was leaning towards Stillen till you guys started posting about the new Hotchkis w/ the collar... Any new updates/info/complaints??? Thanks!!!
Old Jun 28, 2009 | 12:59 AM
  #314
RaginRaj11's Avatar
anyone running the eibach sway bars? How do you like them?
Old Jun 28, 2009 | 09:31 AM
  #315
Texasscout's Avatar
Had my Hotchkis bars for two years now. Best investment I have made. No rattles, no squeaks (if you use the grease they supply) and easy to install.
You have already rated this thread Rating: Thread Rating: 4 votes, 4.75 average.
