Sway Bar Summary!
Rating: Thread Rating: 4 votes, 4.75 average.
Old Aug 9, 2007 | 01:01 PM
  #241
rockd's Avatar
As expected, my hotchkis sways have shot my front passenger side stabilizer link (after only two weeks)... no big surprise, but it's just a pain in the a$$. Gonna install the revised endlinks on the front... hopefully they're beefy enough to handle the added strain...
Old Aug 16, 2007 | 10:10 AM
  #242
kuhntar's Avatar
So does anyone have the stats for the imporved stiffness of any sway bar kits comapred to the 05-07 coupes with sport package?
Old Oct 18, 2007 | 02:08 AM
  #243
str8dum1's Avatar
why is this as expected? do you have the new model sways with the welded collars?
Old Dec 13, 2007 | 11:44 AM
  #244
Texasscout's Avatar
Done a little reading here, but I have a question: Is there a difference in the Sport and non-sport sways? Will changing the sport sways to aftermarkets make a noticeable difference?
Old Dec 14, 2007 | 01:11 AM
  #245
ON's Avatar
ON
Yes. I changed my sport sways out with Stillen's sways and it definitely corners better and has less body roll.
Old Dec 14, 2007 | 12:59 PM
  #246
ABNERG35's Avatar
G-SMACK THIS
SO ARE THE hotchkis NOT GOOD QUALITY
Old Dec 14, 2007 | 01:02 PM
  #247
Jeff92se's Avatar
Red Card Crew
Um they are great quality. If you are referring to the above post about the end link, IMHO that would have happened to him regardless of the maker he chose. It's the increased stiffness of the bar tha did it.
Old Dec 14, 2007 | 01:07 PM
  #248
ABNERG35's Avatar
G-SMACK THIS
OK, I JUST BOUGHT SOME hotchkis FOR $150 FROM A GUY DOWN THE STREET AND HE GAVE ME NEW BUSHINGS SO I WAS JUST WONDERING IF IT WAS A GOOD DEAL OR I SHOULD HAVE JUST WENT WITH SOMETHING ELSE.
Old Dec 14, 2007 | 02:24 PM
  #249
codeflux's Avatar
correct - end links can go out with any aftermarket sway bars that provide higher stiffness. one thing that hotchkis sways lack is the collars - no collars make them slide more freely left/right, weakening the end links. i ended up getting aluminum collars from mcmaster, but they sometimes knock. stillent sways do have collars, and provide better stiffness increase than hotchkis, percentage-wise.
Old Dec 14, 2007 | 02:42 PM
  #250
rockd's Avatar
yes, i have the newest model. it's expected because our OEM endlinks are not meant to handle the increased stiffness of aftermarket sway bars... especially if you put them on the stiffest setting. i'm not saying it's a guarantee, but you run a very high risk of busting your endlinks if you run aftermarket sway bars on stiff settings... on the bright side, endlinks are cheap (20 - 30 bucks) and easy to replace.
Old Dec 14, 2007 | 02:45 PM
  #251
rockd's Avatar
yea, i never meant to say that the hotchkis bars busted my endlink... just that any aftermarket bar would've probably done it. it's all about the increased stress put on the endlinks due to the stiffer bars
as a side note, I decreased the stiffness to low-med (hole 2) in the front (dont remember what the rear is set to), and the new OEM endlinks are holding up fine
  #252
Jeff92se's Avatar
Red Card Crew
I agree. When I bought mine used, they came with the collars and I've had no problems with them. I haven't experienced any knock that I can tell.
All Hotchkis bars come with built in collars and have 4 adjustment holes vs 3 (older models).
Old Dec 14, 2007 | 03:14 PM
  #253
ABNERG35's Avatar
G-SMACK THIS
I Have Not Looked At Them Close Yet But Any Sway Is Better Than Stock.
Old Dec 14, 2007 | 03:27 PM
  #254
redlude97's Avatar
Swaybars are not about getting the stiffest possible setting, usually this results in poorer performance except for on perfectly flat smooth track surfaces. There are downsides to the stillens as well as they do not come with new bushings and reuse the stock ones or new ones have to be purchased. The point is not moot though because the new hotchkis bars with welded collars and 4 front adjustment points are a better buy than the stillens IMO.
Old Dec 30, 2007 | 03:53 PM
  #255
JDM_Cain's Avatar
great write up..im in the market for a sway bar kit for my 03 sedan
You have already rated this thread Rating: Thread Rating: 4 votes, 4.75 average.
