Suspension creaking noise - NOT SUSPENSION
Mar 9, 2008 | 08:37 PM
  #91
Diagnosing compression rods
Is there a way to tell if they are bad by looking at them? In some other forums I have read about torn or cracked bushings. Mine look fine, but the Infiniti service tech said I need new compression rods the other day when I was getting other work done. My '03 G35 Sedan makes a low growling noise when switching into drive and turning right after backing out of my driveway in the morning.
Salt_fly
Reply 0
Mar 9, 2008 | 08:54 PM
  #92
ive had squeaking noise in my front end for months now! pissing me off
Reply 0
Mar 11, 2008 | 08:49 AM
  #93
So for the last 3 weeks, I've got a gawd awful creaking noise in the rear of my car whenever I brake -- sounds like two fat kids bouncing on a bed....annoying. (and had the brakes checked first) I'm running stillens fr/bk for over 2 years now, without a single issue. I had the OEM bushings regreased, and the noise went away for about 2 days and now has come back.....I'm gonna assume they stock bushings have gone bad and I should just go ahead and pick up new poly. bushings?
TIA
Reply 0
Mar 15, 2008 | 11:01 AM
  #94
So does anyone know if this is covered for sure? I just got back from a service and they quoted me for additional work which included bushings, bushings brackets and stabilizer link!
Its pretty ridiculous the amount of times dealers try and and nickel and dime you on services.
Reply 0
Mar 15, 2008 | 10:08 PM
  #95
Quote: So does anyone know if this is covered for sure? I just got back from a service and they quoted me for additional work which included bushings, bushings brackets and stabilizer link!
mine was covered... end links was all that was needed... what bushings are they replacing? If it's sway bar bushings I highly doubt thats needed...
Reply 0
Mar 16, 2008 | 06:14 AM
  #96
Sway bar bushing brackets, Sway bar bushings, Sway bar link whichi figure is the stabilizer link $270.94+tax
Reply 0
Apr 1, 2008 | 02:50 PM
  #97
Quote: So for the last 3 weeks, I've got a gawd awful creaking noise in the rear of my car whenever I brake -- sounds like two fat kids bouncing on a bed....annoying. (and had the brakes checked first) I'm running stillens fr/bk for over 2 years now, without a single issue. I had the OEM bushings regreased, and the noise went away for about 2 days and now has come back.....I'm gonna assume they stock bushings have gone bad and I should just go ahead and pick up new poly. bushings?
TIA
Replaced the bushings on the rear sways - and I still ahve this loud squeaking/creaking in the rear whenever I brake.
Reply 0
Jun 13, 2008 | 08:10 PM
  #98
does all of this fall under bumper to bumper or drivetrain warranty?
Reply 0
Jun 13, 2008 | 08:34 PM
  #99
I was able to get it done under the 60k mi warranty.
Reply 0
Aug 22, 2008 | 03:57 AM
  #100
i got an o4 coupe and i get a creakin noise from the rear driver side and noticed that it is actually sitting lower then the passenger side. what could this be?? i have ideas but if anyones knows please give me some info.
Reply 0
Aug 25, 2008 | 07:25 PM
  #101
Quote: ...i get a creakin noise from the rear driver side.
The compression rods are in the front, so your problem is something else. Suggest doing a search or creating a new thread.
Reply 0
Sep 5, 2008 | 06:59 PM
  #102
Are you guys hearing the compression rods when you brake?
Reply 0
Sep 7, 2008 | 10:42 AM
  #103
Quote: Are you guys hearing the compression rods when you brake?
I dealt with the compression rod problem for over 3 years, and generally came to understand exactly what circumstances would set off the noise. But I never made any correlation with braking. So, the answer is no.
Reply 0
Nov 17, 2008 | 05:34 PM
  #104
Add me to the list....took the car into Bob Moore Infiniti in OKC this morning with TSB in hand and they did a fantastic job of analyzing and fixing the problem. No hassles whatsoever.
Reply 0
Nov 28, 2008 | 11:12 PM
  #105
Am I in the right thread?
I go over a bump, speed bump or make a hard turn I hear creaking like a runner's knee joint. Especially after a speed bump, the bounce sounds rusty like bad coils in a bed. What is it?
Reply 0
