Suspension creaking noise - NOT SUSPENSION
Old Sep 12, 2010 | 09:56 AM
  #121
35bills's Avatar
^^^ Might be a bushing or a compression rod....
Old Sep 13, 2010 | 01:45 AM
  #122
Xx2006GCOUPExX's Avatar
just noticed today when I push the breaks the sound goes away.
Old Sep 18, 2010 | 04:40 PM
  #123
mbian's Avatar
I just got a pair compression rod from TaiWG35 TODAY, Nice stuff, unbeatable price. hope this will get rid of my clunk noise.
Attached Thumbnails Suspension creaking noise - NOT SUSPENSION-img00197-20100918-1606.jpg
Old Sep 20, 2010 | 04:07 PM
  #124
g35oahu's Avatar
i have 04 coupe...got that same clunking noise at slow speeds when going over bumps from my passenger side..and that squeek noise on both side when i turn at slow speeds..im assuming by what everyone has said that the compression rods are the problem?? does spraying silicone really resolve this problem??
Old Oct 4, 2010 | 07:00 PM
  #125
bigjee's Avatar
Hey everyone.
Just read this post and I have experienced a creaking sound but its different from what most people here are describing.
The sound from car comes just once.
It is similar to metal being twisted.
Lasts about 2 seconds and happens regardless of the height of the car or how much the steering is turned.
It seems like its speed based and occurs at a certain speed.
It doesnt occur until the car is switched of and started again.
Once it starts rolling then the sound occurs again.
I have no idea what it is.
I will try and record a sound clip if possible.
But until then has someone else experienced this noise.
Old Oct 8, 2010 | 02:05 AM
  #126
BigVicG35's Avatar
I got the same damn problem.. i need answers lol sounds like ****..
Old Oct 9, 2010 | 04:15 PM
  #127
mbian's Avatar
replace compression rod fixed the clunking noise. the ball joint has a little play, almost unnoticeable.
Old Nov 5, 2010 | 03:26 PM
  #128
BonnieRose's Avatar
I just had the compression rods replaced after 7 years and 53,000 miles so from what I see I was lucky. They did advise an alignment too.
Old Dec 26, 2010 | 03:20 AM
  #129
migelito1's Avatar
I just change my suspenssio for true coil. But now i hire some noeise bad noiese is drivinme crazy is just when i brake is like something is rubbing touching the brake songs like the mufler is touching the flour .and the other noiese comed on the left side is a clinki noise when i step on the clutch. Is anybody who have the same problem.
Old Dec 26, 2010 | 03:25 AM
  #130
akoustic's Avatar
Okay now I'm more confused. No offense.
Old Dec 26, 2010 | 04:27 AM
  #131
OBsessed's Avatar
Translated:
I just changed my suspension for a true coilover setup, but now I'm hearing some noise that is driving me crazy. It only happens when I brake and sounds like something is rubbing or touching the brake, kinda sounds like the muffler is touching the floor. And another noise comes from the left side and is a clinking noise when I step on the clutch. Does anyone else have the same problem?
Old Dec 26, 2010 | 08:52 AM
  #132
VQEric's Avatar
Originally Posted by bigjee
Hey everyone.
Sounds like the ABS self check which is completely normal. Search "ABS self check" or "ABS test" and you'll find others' descriptions of the sounds like this one https://g35driver.com/forums/g35-sed...eleration.html
Old Dec 26, 2010 | 04:58 PM
  #133
migelito1's Avatar
Well ok.this is what happend like. A month ago i intalle. Coilover on my g. Abd like week ago i starter hiring a bad noise on therear right side. Sounds like when i brake is lek the. Disk brake es rubbing with the metal. Bihind the disck but i check and not everything looks good but is just the noise is bother me a lot. I think im gonna have to take my car to the dealer. I is anyone who have the problem.
Old Jan 21, 2011 | 10:14 AM
  #134
buzzking's Avatar
Is the TSB only for sedans?
I have a coupe!
I also heard the compression rods and bushing can be covered under warranty and I am at 60K miles with an extended warranty. Does anyone know which extended warranty from infiniti I need or does it not matter?
Old Apr 1, 2011 | 08:41 PM
  #135
MMAREF's Avatar
That sound like the brakes.
