tire size question
tire size question
so lets say i have ordered a set of rims that are 18x8.5, now i need tires.
so i am thinking 245/40 or 45/18.
what do u guys think of that size what one would look better on a non lowered sedan. should i be thinking about another size....
i am looking for summer tires only.
next question who has the best deals out there?
If you are trying to match the OE specs of a 17" wheel and 215/55 tires best bet is a 235/45/18 tire. That's almost exactly the same diameter-.06% larger. The next best is a 245/45/18 which is 1.41% larger diameter all around and well within the accepted 3% differential so there should be no problems with VDC or ABS etc. That's probably nice to fill the wells a touch more on non lowered car.
The 245/40/18 is too small a diameter although maybe someone on here has some direct experience with trying this set up. You would need to run a 19" 235/40 for that size tire to match OE. Staggered set up is only for the coupe.
would there be a difference between a 40 and a 45 sidewall? 40 might end up being easier to come by. but 45 would fill up the wheel gap more.... i think i want 245 for the width anyways. more traction for the track.
I posted a few underwater pics I took on the holiday here: https://g35driver.com/forums/photography/275068-underwater-pics-mayan-riviera.html
hey guys,,,
i have a question not trying to take over this thread.
i have an 03 coupe , with stock rims the stock set-up is 245/45/18 , know i want to up grade to 255/45/18 , has any1 done that or is it possable , midas says no it well rub but i have seen 285 on the rear set-up with no problems , but then againg i am still useing my stock rims
hey guys,,,
Then you need to look up the tire data to see if it matches your wheel width.
e.g. Tirerack tables.
^that's what I looked at for reference On an 18" the 235/45 is the closest to OE and the 245/45 is a little larger but should be okay. The 8.5" will work perfectly with either. The 40's don't really match up on an 18" wheel.
