I need to buy a powerball mini.
Old Sep 20, 2006 | 09:26 PM
GThIrtYFiZle's Avatar
Does anyone know where I can get a powerball mini in order for me to polish my wheels. And what exactly is it that I need to do the whole job. Where can I buy it in Queens. TIA
Old Sep 21, 2006 | 08:04 AM
superchargedg's Avatar
i know pep boys sells it.
Old Sep 21, 2006 | 11:30 AM
Punchit's Avatar
Have you used the powerball yet? What did you think of it? I have not used it but can't imagine it working well. It seems to me that it would grind contaminates into any wheel with a fine finish. I'd think I'll just stick to my P21S metal polishing soap until I hear of something better.
Old Sep 21, 2006 | 01:25 PM
its total junk,for anything other then old style aluminum uncoated wheels.
Old Sep 21, 2006 | 08:19 PM
TwoK4drSi's Avatar
How well does this work?
Old Sep 21, 2006 | 08:29 PM
DHCrocks's Avatar
it works great on polished wheels, comes out way better then Mothers billet or mag&aluminum polish by hand. finish is truly mirror like. only down sides are you can't get up into the tight areas and it flings polish everywhere. It even was able to take out fine hairline scratches in my lips that hand polishing couldn't.
of course you need to wash the rims first to get rid of all loose debris and doing so will reduce the likely hood of scratching the wheels.
Old Sep 22, 2006 | 06:18 PM
How much does the whole thing go for. And what do i need to use with. Also, how do I use it, can I f*ck the rims up if I dont do it the right way, like using a maschine to compound, which can lave swirl marks. Is it pretty easy and straight forward. My lips are just polished aluminum which should work perfectly with the machine.
Old Sep 22, 2006 | 07:25 PM
DHCrocks's Avatar
It's super easy to use, just liberally apply the polish (mothers power metal liquid polish) to the ball and go to it. I got the ball for around $20 and the polish was $6. after you're done wipe up the black residue with a microfiber towel and you're done. As long as the ball is clean you won't scratch the aluminum, just make sure you don't put it on the ground or it will pick up some dirt and that could scratch it. it won't leave swirl marks in fact it took out the really fine scratches I had on the lips. Only use on bare metal, not on anodized, painted or clearcoated rims.
Old Sep 22, 2006 | 08:09 PM
bobshuai's Avatar
so it won't work with Volk GT-C rims?
Old Sep 23, 2006 | 10:35 AM
DHCrocks's Avatar
I don't think so, I believe volks have either clear coated or anodized lips and painted centers.
Old Sep 23, 2006 | 11:39 AM
aszatk01's Avatar
search for my post in this forum a month or so ago
i did a nice write-up on it with the mothers billet polish
Old Sep 23, 2006 | 05:39 PM
can I use it with a different type of polish, like turtle waxes aluminum polish?
1Typhoon
Sep 25, 2015 08:45 PM
Jpete
Sep 25, 2015 01:38 PM
Dannyy06
Sep 25, 2015 11:32 AM
mamba24
Sep 15, 2015 10:37 PM
twentyeggs
Sep 11, 2015 03:58 PM
