Ask a Professional Detailer...
Rating: Thread Rating: 10 votes, 5.00 average.
Old Nov 11, 2011 | 12:24 PM
  #1876
Detailed Image's Avatar
Originally Posted by threatcon07
Must have ran over some freshly paved tar...(Thanks for the invisible warning sign Orange County!) got all up in the wheelwell, along the bottom of the sideskirt, and even into the rear wheelwell. Got most of the stuff off the paint (from the visible part of the side skirt, underneath is still caked on) with goo gone and a claybar...but the other stuff doesn't seem to want to come off, even using tarminator. What do you recommend? Thanks!
Man I've almost never had the Tarminator fail on me for the removal of tar. I would spray the tarminator on a soft cloth and hold it on the surface for about 1 minute, hopefully it will dissolve it further. If that doesn't work I'd probably try a medium grade clay bar assuming the build ups are not overly large. If that doesn't work I would move up to mineral spirits or the 3M Adhesive Remover, but please thoroughly wash and clean the area afterward.
Greg @ DI
Old Nov 11, 2011 | 12:28 PM
  #1877
Originally Posted by Eye Eat Ketchup
so from reading the first post, it wold be as follows:
wash
clay
if necessary apply compound
sealant
optional - wax
Just want to make sure. Too bad I only bought 1 of each pad by accident. Yesterday was a super sale too.
Are there compounds specific to OB?
There are not polishes you need for certain colors and the M105 (2x orange pads) and then the M205 (2x white pads) should work great. Otherwise you have the process down and it should really help make the paint look like new. The detailing guide should be a big help and if needed don't hesitate to ask me any questions.
Greg @ DI
Old Nov 12, 2011 | 03:23 AM
  #1878
threatcon07's Avatar
I will tackle this again shortly..the problem seems like since most of it is on the bottom of the sideskirt, even if I saturate the area, it drips down. So I did hold a microfiber towel against it after spraying...but it didn't seem to work. Just a hard area to work on as I either have to be on my back, or constantly laying down and getting back up. Wish I still had my creeper.
On another note, I plan on doing some M105/M205 correction soon...was wondering if I need to hit the area with alcohol/water mix after applying M105, and before proceeding with M205? Thanks!
Greg @ DI
Old Nov 15, 2011 | 12:53 AM
  #1879
jutn35's Avatar
G35 Coupe
i accidentally put major swirl marks on my moms lexus wind shield by trying to remove hard water deposits, i got those out but now i have swirl marks all over, what can i do !? I tryed an orbital with rubbing compound by turtle wax and that barely put a dent in it "/
HELP PLEASE !
Old Nov 15, 2011 | 09:55 PM
  #1880
wechslerl's Avatar
General question.
Have a black dashboard with multiple cracks.
Whats the bast way to repair it or replace it
Old Nov 16, 2011 | 10:44 AM
  #1881
wechslerl's Avatar
I am referring to the vinyl/leather dashboard cracked by the sun !
Old Nov 16, 2011 | 02:16 PM
  #1882
wstalker's Avatar
how about what you would do to the inside of a car
Old Nov 21, 2011 | 10:46 AM
  #1883
Many detailers I know have stopped using the 50/50 mix of IPA. It's traditionally used after both polishes are used to remove any oils they might leave behind, to enhance the durability of a sealant. Good luck with this and keep us posted on your results!
Greg @ DI
Old Nov 21, 2011 | 10:49 AM
  #1884
HELP PLEASE !
Glass is extremely hard compared to the clear coat so it's really challenging to polish. The Glass Science Glass Scrub is my go to deep cleaner for glass as it removes a lot of really stubborn contaminants, however it's not really designed to remove swirls. For that I'd suggest googling around for a glass polishing kit if you want to tackle it on your own. Another option, which you and she may not like, is submitting an insurance claim usually you can get glass replaced for $0 deductible, but obviously you have to check the policy. Sorry I can't be more helpful here.
Greg @ DI
Old Nov 21, 2011 | 10:52 AM
  #1885
Originally Posted by wechslerl
General question.
Unfortunately if it's cracked you're going to have replace it for a total fix, try looking up the part #. The Leatherique Rejuvenator Oil is a good at conditioning leather, vinyl, rubber, etc. so if you want to make it look a bit better this is a great option, but it will not fix the cracks! If you want to prevent further UV damage the 303 Aerospace Protectant is our best protectant. Let me know if you have any questions.
Greg @ DI
Old Nov 21, 2011 | 10:56 AM
  #1886
As always it depends on the car, it's condition and my goals, but here is a general outline. The 303 Cleaner & Spot Remover is my go to interior cleaner for the dashboard, doors, console, carpets, fabrics, etc. Just wipe it on or brush it in the fabrics and it cleans quickly and safely. 303 Aerospace Protectant protects just about the whole interior (vinyl, plastic, rubber, leather). It blocks out UV rays and preserves the finish so apply it to the dashboard, doors, console, arm rests, exterior trim, rubber moldings, etc. etc. Protecting the carpets and mats is super easy just mist the 303 High Tech Fabric Guard on them and you are done! It will help repel moisture and the fabric will look exactly the same. It's such an easy step that many people skip over but trust me it's well worth it. The SONAX Leather Foam can be used on the leather as well to keep it clean, without any extra gloss or shine that is generally not good for the leather. The Chemical Guys Window Clean and two microfiber towels are great on the glass!
Let me know if you have any other questions and I'll be happy to help.
Greg @ DI
Old Nov 23, 2011 | 12:56 PM
  #1887
Eye Eat Ketchup's Avatar
Greg @ DI
hi greg,
read the guide and i have some questions, I already bought the CG 50/500 and CG Jetseal 109. Just want to make sure...the M105/M205 are polishes (need orange or yellow/white). Then polish with the CG Jetseal 109 (white pad) and wax with CG 50/50 (black pad)?
Wondering how to do this correctly especially since I already bought the CG 50/50 and CG Jetseal 109.
Also, what's the best way to apply the water spot remover? I have a ton of hardwater marks all over my car. I figure if I polish it'll go away, but I don't know about the windows. Just elbow grease?
Old Nov 24, 2011 | 12:00 PM
  #1888
hi greg,
For watermarks on the glass I highly recommend the Glass Science Glass Scrub. Glass is very hard and this product works extremely well at removing these extra stubborn contaminants. The Chemical Guys Water Spot Remover is applied by hand and a soft applicator or cloth. I would wear a rubber glove and wipe with light to medium pressure on the affected areas. I wash the car before hand and after to be on the safe side.
As for pad combos here is what I'd suggest:
M105 Orange or Cyan Pad
M205 White or Tangerine Pad
Jetseal 109 Blue Pad
50/50 hand applied
Greg @ DI
Old Nov 29, 2011 | 02:43 AM
  #1889
RA0523252's Avatar
What's the best buffer I could get for $150? For detailing purposes such as buffing, waxing, etc.
And what's the difference between and orbital one and a non-orbital one?
Old Nov 30, 2011 | 03:32 PM
  #1890
06g35meister's Avatar
Alright im a noobie and i have a question from the man himself, if you had $100-$200 dollars and a brand new 7424xp on your doorstep, looking at a pretty severely swirled lazer red G35, what would you buy? I am reading around but honestly overwhelmed with the number of different articles suggesting different items. I am looking into the poorboys kits, i need a good compound (my mirrors are faded to hell) and would like a good "wet" and shiny look, but more important is the fact that the car is not garaged, so i need weather protection and something that seals really well. I am looking only for paint correction as i have the headlights and interior stuff i am very happy with.
Pad suggestions are always welcome as well.
You have already rated this thread Rating: Thread Rating: 10 votes, 5.00 average.
