wax and then wax again???
Old Dec 15, 2004 | 01:47 PM
g35sammy's Avatar
hey guys i was wondering if you can do this? wax your car, and then wax it right after again? in essence putting 2 coats on right after another????? thanks for your help!~!
Old Dec 15, 2004 | 02:06 PM
bsgoren's Avatar
Why not? Not to be such a smarta-s , but when clean something, do you think it hurts to clean it again immediately after? Adding more than 1 coat of wax is likely to provide you with a better shine. I use the Klasse (all-in-one) AIO synthetic wax as a base coat (which lasts about 6 mo.) and top it off (after letting it cure for 12 hours) with several coats (I think I've now done about 4 coats in the past 10 mo.) of Pinnacle Liq. Souveran Carnuba wax on top. It's almost time for me to start over with the Klasse again. Enjoy!
Attached Thumbnails wax and then wax again???-bsgoren-g35-sedan.jpg   wax and then wax again???-g35-after-klasse-pinnacle-combo2.jpg
Old Dec 15, 2004 | 02:34 PM
tkman00's Avatar
actually, there's nothing wrong with it at all. try to apply as light a coat as possible. wait around 6 hours for it to set, and then throw on another coat to cover any spots you may have missed. i'd probably stop at 2. you can continue if you want, but you'd just be wasting product since you wouldn't be achieving any more depth.
Old Dec 15, 2004 | 02:46 PM
g35sammy's Avatar
yea but what im asking is im going to wax my car [ meaning apply wax
and let cure and take off], and then literally 10 mins later do the
whole process again.
Old Dec 15, 2004 | 02:47 PM
g35sammy's Avatar
so wait 6 hrs, don't take off the wax, and then throw on another coat if i missed spots~??? is it ok to leave wax on for THAt long?
Old Dec 15, 2004 | 02:54 PM
tkman00's Avatar
heh, sorry
buff it off and then wax again (if you'd like). is it ok, sure, but it may take forever to remove the wax afterwards.
Old Dec 15, 2004 | 03:10 PM
Msedanman's Avatar
O.F. Administrator
If it cures properly and dries, you can leave it on for as long as you like. I'd remove (buff off) that coat first, tho, b4 applying another. This is best done in a heated garage, and of course not driving between coats.
Old Dec 17, 2004 | 09:06 AM
lgangi's Avatar
If you're using a wax with cleaners, it will remove the first coat. I've had great results by "topping" with carnuba based wax like meguirs #16.. Also, the time that you wait for second coat has a lot to do with humidity.. Higher humidity, longer wait time. If you can, I'd suggest more like 24 hours...
Old Dec 21, 2004 | 08:10 PM
tod071's Avatar
Use Zaino. If used with ZFX, coats can be applied within an hour. Not to mention alot easier to apply.
Old Dec 28, 2004 | 03:48 PM
g35detailer's Avatar
Addidng multiple coats is good! Try to give it a bit of time to dry between coats and a heated and non humib area to do thw work will make your life alot easier.
Just as mentioned though don't drive the car between coats.
And always us a quick spray detailer every time you wash the car to help replenish the wax.
Tmatheso
Dec 13, 2015 03:24 PM
TNRocker
Sep 21, 2015 08:36 AM
edwinisdumb15
SOCAL Meetings & Events
Sep 18, 2015 11:25 PM
bigmike
Sep 17, 2015 01:58 PM
