[DFW] What have you done to your G Today?
Old Mar 6, 2011 | 10:27 AM
  #4546
g35man04's Avatar
CLUB MODERATOR
Originally Posted by PhGit
changed the LEDs in my clear corners from WLED-W-90 to WLED-CW5 (Super Wide Viewing Angle bulb uses 4 radially mounted LEDs aiming out the sides and one High Flux LED on top) Sooo much better! Yeah, still not strips but some day.
Also changed license plate lights from a cheap version of WLED-NW6 to WLED-HP5 (5 High Power SMD LEDs). Hella bright!
Actually on my other car I took out the instrument cluster and replaced the lights with red LEDs since they were mostly burned out anyway. Is this fairly easy to do on a G?
since your an 06 g35 your cluster has LED's..however all of them will need to be soldered. meaning solder off old and replace with new. Sexyrob can do them if your wanting a full interior conversion. he just finished my 04 which is a pretty big bitch.
Old Mar 6, 2011 | 10:30 AM
  #4547
g35man04's Avatar
CLUB MODERATOR
Originally Posted by Princedrama
I'll be working on my car next week probably gonna start the wire tuck.
I personally think your guy doing the wire tuck for the so called price he is stating doesnt know what he is getting himself into unfortunately.....he doesnt understand that you have to extend alot of wires...meaning solder extende and re-solder all new wires. then you have to wrap every single different wiring location and hide it behind. remove the so called 20 brackets attached to the wiring harness.......
has he done a G before? or is he basing this off of Low riders and the lexus he just did?? just curious. Trucks are alot easier with alot more room to work with. also is he meaning just main harness?? or tucking headlight wiring harnesses, main battery cable??? you need to make sure he grounds off the original grounds back to a good spot on your engine as well
Old Mar 6, 2011 | 11:26 AM
  #4548
hound's Avatar
^ i was thinking the same thing.
Old Mar 6, 2011 | 02:08 PM
  #4549
almost3flips's Avatar
Dropped the car off for an allignment
Old Mar 6, 2011 | 02:14 PM
  #4550
That G Gray's Avatar
Originally Posted by g35man04
i personally think your guy doing the wire tuck for the so called price he is stating doesnt know what he is getting himself into unfortunately.....he doesnt understand that you have to extend alot of wires...meaning solder extende and re-solder all new wires. Then you have to wrap every single different wiring location and hide it behind. Remove the so called 20 brackets attached to the wiring harness.......
Has he done a g before? Or is he basing this off of low riders and the lexus he just did?? Just curious. Trucks are alot easier with alot more room to work with. Also is he meaning just main harness?? Or tucking headlight wiring harnesses, main battery cable??? You need to make sure he grounds off the original grounds back to a good spot on your engine as well
+1000
Old Mar 6, 2011 | 02:30 PM
  #4551
JaE35's Avatar
Moderator
G35 Sedan
How did your install go?
Old Mar 6, 2011 | 02:42 PM
  #4552
Man...started at 12 and finished at 9.... I'll just say it was a learning experience lol I have crappy phone pics but will upload better ones when I get home
Old Mar 6, 2011 | 02:44 PM
  #4553
JaE35's Avatar
Moderator
G35 Sedan
lol you must have done your fronts first? Think you'll need another alignment after about a week? Look forward to seeing the pics
Old Mar 6, 2011 | 02:49 PM
  #4554
Yeah I'm just doing it now because I have a lot of driving to do in the next few days and I'm still waiting on that rear camber kit.
Whenever I install that which will probably be next weekend, Ill get one final allignment to seal it all
Lifetime Allignment feels good
And yes I did the fronts first lol
Old Mar 6, 2011 | 07:23 PM
  #4555
Last month
Wheel Gap
Today
Old Mar 6, 2011 | 07:26 PM
  #4556
Princedrama's Avatar
Lol shouldve went lower haha.
Old Mar 6, 2011 | 07:35 PM
  #4557
I can't man! Roads will eat me aliveee
Plus I don't want to drive 2 mph over everything either...but I do secretly want more drop... lol
Old Mar 6, 2011 | 07:36 PM
  #4558
VicariousVision's Avatar
^ Not if he doesn't want to scrape the hell out of his bumper and sides like you do, Drama. He's at the perfect daily-driver height...I should know, he left them at the same settings that I had them at on mine.
You already know this, but it looks BALLER Phi! Really offsets the wheels perfectly now. Nice job man.
Old Mar 6, 2011 | 07:44 PM
  #4559
Yes Brit...perfect DD
You hooked it up for sure! Coils and amazing presets haha
Thanks man and I can't wait to see the next step with your car! You know that I love your wheels....
Old Mar 6, 2011 | 07:46 PM
  #4560
DrewLe's Avatar
Drop looks good. Like Brit said, perfect DD height without tearing up the bottom of your car
You have already rated this thread Rating: Thread Rating: 1 votes, 1.00 average.
