RPM fluctuating after shifting gears
Old Feb 11, 2008 | 05:23 AM
unclebenny44's Avatar
hi everybody. i've noticed that my rpm is dipping and rising slightly after i change gears, especially at higher speeds. does this mean my clutch is shot? i have a 2005 g35 sedan 6 speed. any advise would help. if it is shot does anyone know of any good places(cheap) that i can bring it to in orange county, california? thanks guys.
Old Feb 11, 2008 | 02:16 PM
in2win's Avatar
wait you are shifting and the rpms are dropping and then rising. Im not trying to be a jerk but it sounds like thats why we shift in a manual car. Sounds like your not rev-matching and your rpms are dropping before the clutch catches again...thus making them go back up. Search on here for rev-matching, but for kicks "blip" the throttle when you shift and the rpms wont drop as much.
Old Feb 11, 2008 | 05:16 PM
AGThing1227's Avatar
Yea, I don't think he is trying to be a smartass. But elaberate more on your problem. From what you said, it sounds normal. We gas it>RPM's go up>we shift up>RPM's go down>We gas it>RPM's go up. So restate your problem so maybe we can give you more help.
Check this out: https://g35driver.com/forums/attachm...4&d=1185758153
^That should maybe clarify some things.
-AGThing1227
Old Feb 11, 2008 | 05:17 PM
Also do you hear grinding? Just out of curiosity.
Old Feb 11, 2008 | 06:00 PM
in2win's Avatar
I was just saying that because when I first got my car and not too well first in driving stick fast in our kinda difficult cars, this is what I thought too. Its also because our stock clutch has such a high engagement point so it takes longer to work the clutch hence the rpms dropping with the clutch in longer and not rev matching
Old Feb 11, 2008 | 10:13 PM
Hi everybody. I've had the car for 3 years and it's just starting to happen. I'll elaborate a little more. What's happening is after I shift and I'm accelerating the RPM will dip even though I'm pushing down on the gas. Then it'll rise up a little and then dip again. Hope that makes more sense. Thanks guys.
Old Feb 11, 2008 | 10:22 PM
MIA BlazinVQ's Avatar
brb getting cut
yep it sounds like your clutch is toast. it might be a great time to get an aftermarket setup for your clutch and flywheel.
Old Feb 12, 2008 | 03:54 PM
Originally Posted by HomieG35
Yeah, if you get ina gear and push the gas again and the RPMs are low, then raise some, then go back down, it's the clutch. May have some time left if you behave, but you don't wanna get stranded somewhere.
Why not? Thats always fun. In all seriousness, that would suck!
Old Feb 12, 2008 | 04:24 PM
Deezflip's Avatar
so is this a sign of the clutch slipping? Is that what you mean when you say "shot"? I don't understand why the RPM would dip when pressing the gas pedal and then shooting back up. IMO, this would be a sign of throttle, sparkplug, or a sudden burst of air but not making the combustion immediately
I thought a sign knowing that the clutch is slipping is when your on a cruising speed and you mash the gas pedal while on a higher gear, if the RPM increases and the car barely moves, It's slipping.
Picture Share
Feb 4, 2018 12:41 PM
RWDguy4238
Sep 30, 2015 12:13 AM
vamarris
Sep 26, 2015 12:56 PM
blnewt
Sep 25, 2015 01:48 PM
