carbon fiber driveshaft???
Old Feb 15, 2012 | 12:24 AM
  #256
PR-G35Driver's Avatar
carbon driveshafts came in
Old Feb 15, 2012 | 12:31 AM
  #257
lsmooth81's Avatar
^^Nice, I really want one of these
Old Feb 15, 2012 | 12:58 AM
  #258
purpleharo's Avatar
def might grab one of these!!!
Old Feb 15, 2012 | 01:06 AM
  #259
lsmooth81's Avatar
I don't know if this was alreay asked, but how much better is the CF over the aluminum?
Old Feb 15, 2012 | 01:14 AM
  #260
the only real benefit of the carbon over aluminum is being more safeproof and kudo points to say you got a carbon one. also the carbon driveshaft absorbs all of that vibration better for a better feel compared to an aluminum.
but for the price of the aluminum it simply can be beat
Old Feb 15, 2012 | 01:15 AM
  #261
** can't be beat
Old Feb 15, 2012 | 09:19 AM
  #262
Dsskyline's Avatar
Nice!!! PR-G!!! Do you think there will be a NA dyno within a week or two? So far the only dynos are on boosted cars.
The turbo G gained 20+hp only changing out the shaft. The car was baselined, shaft installed, and dynoed again in 2hrs same day.
Gzilla gained 60hp the only difference with his it wasn't same day don't know the correction factor and weather conditions.
Hills told me the correction factor was the same and almost no change in weather when they did the G35 since it's cold here.
Old Feb 15, 2012 | 11:27 AM
  #263
808_G will most likely have his on before me. I still gotta buy another exhaust an tires to get back on the road
Old Feb 15, 2012 | 02:16 PM
  #264
suprasam's Avatar
I'm curious of the torque rating these can handle. The number's sound good but how much boost and torque were these guys pushing? I put down 500 ftlbs, which isn't too much but I want to make sure these will hold it.
Old Feb 15, 2012 | 02:23 PM
  #265
SDGenius's Avatar
meatbag runs one on his 844whp/686tq setup
Old Feb 15, 2012 | 03:14 PM
  #266
caelric's Avatar
Question: how difficult is the install? Thinking about getting on of these for my JWT TT G35(actually, the Z1 Motorsports aluminum one, for the price), but I like to do most of the work on my G myself.
Any ideas from anyone who has either done the install themselves, or at least how long the shop took to do it?
Old Feb 15, 2012 | 03:17 PM
  #267
SDGenius's Avatar
it takes longer to get your exhaust out of the way then it does to uninstall your OEM shaft and install the 1pc.
Old Feb 15, 2012 | 03:28 PM
  #268
caelric's Avatar
I've installed two seperate exhausts on my G, so I think I can handle that, then. Thanks.
Old Feb 15, 2012 | 08:14 PM
  #269
Row2k's Avatar
20 Year Member
G35 Coupe
Got mine ! sooo sexy, i have to install a new clutch so I'll be swapping it in at the same time....also I discovered today my passenger md ART test pipe is cracked and leaking gas like a chubby kid at Wendies....fml
Old Feb 15, 2012 | 08:49 PM
  #270
t6378tp's Avatar
where did it crack, I was planning to make a bracket so it bolts up like the oem cats for mine
