RPM's at 80 MPH
Old Jan 3, 2010 | 01:21 AM
  #256
NFSP G35's Avatar
? = 2B || !2B
^And that's why I want to test it
Old Jan 3, 2010 | 01:32 AM
  #257
Tollboothwilley's Avatar
Ya, guess it would need some testing. How would you program the microcontroller?
Old Jan 3, 2010 | 02:02 AM
  #258
NFSP G35's Avatar
? = 2B || !2B
^Now that, I'm not going to share :P
Old Jan 3, 2010 | 01:13 PM
  #259
OCG35's Avatar
good luck with tricking the ECU... the good thing is its an older version so your chances are probably better than the newer ones... but the ECU and BCM on these cars are very finicky and throw fits when you mess with them... expect many gremlins.
Old Jan 3, 2010 | 03:38 PM
  #260
NFSP G35's Avatar
? = 2B || !2B
^True, but you don't have to trick the newer ones, after all, yours doesn't have that problem... then again, it is a G39
Old Jan 3, 2010 | 03:49 PM
  #261
I only meant, what type of algorithm are you thinking of? when speed > 85 MPH then send 1.05% of sensor value?
Old Jan 3, 2010 | 03:52 PM
  #262
NFSP G35's Avatar
? = 2B || !2B
Sortof something to that extent. (though 3.3->3.5 would be 1.06) but yeah, that's the idea.
Old Jan 3, 2010 | 03:56 PM
  #263
its more like 1.053 (3.53 vs 3.35)
Old Jan 3, 2010 | 04:55 PM
  #264
NFSP G35's Avatar
? = 2B || !2B
^Ah didn't realize the exact ratios (obviously I would look into that in more detail when I actually designed the program)
Old Jan 3, 2010 | 05:14 PM
  #265
OCG35's Avatar
actually its almost 1.054.... 1.0539
3.538 vs 3.357
Old Jan 3, 2010 | 05:18 PM
  #266
NFSP G35's Avatar
? = 2B || !2B
^ 1.0539171879654453380994935954721
I'll be sure to enter this EXACT value into the programming
While we're on the subject, where is a good place to find the exact ratio of each FD?
Old Jan 3, 2010 | 05:32 PM
  #267
OCG35's Avatar
I have 3.3 (3.357) 3.5 (3.538) and 3.7 (3.692) memorized... from various forum research over the years... I cant remember 3.9 and 4.01 though (I have to look for those - I used to know them, but dont remember right now)
I'm sure a Google search will yield results though.
Edit: here's one (for 3.3 & 3.5): http://www.infinitihelp.com/models/2...ifications.htm
Old Jan 3, 2010 | 05:39 PM
  #268
NFSP G35's Avatar
? = 2B || !2B
^ Actually Google search yielded some really good results! Check it out:
http://nico.dreamhosters.com/hosting...ear_ratios.xls
Old Jan 4, 2010 | 12:01 AM
  #269
to be perfectly accurate you would need to count the # of teeth in the ring and pinion of each gear set. Divide the # of teeth in the ring by the # of teeth in the pinion and you have your exact ration.
Old Jan 4, 2010 | 12:24 AM
  #270
NFSP G35's Avatar
? = 2B || !2B
^ Are you and mike in a compitition to see who can be more pedantic?
