DIY 03 G35 Coupe 5AT to 07 G35S 5AT differential swap
Old Mar 19, 2012 | 08:37 PM
  #271
SuperTrooper699's Avatar
Does anyone know how hard this may be to do???????????? This guy is selling parts to a g37 differential. Its the assembly. I have a 3.5fd swap now with lsd. Is it something i can preform or a shop would have to. he is selling it for 140 bucks [IMG][/IMG]
Old Mar 20, 2012 | 05:32 PM
  #272
Maxknuckles's Avatar
I have a 04 coupe 5AT, which car pumpkin (year and type) would i need to get for a direct fit 3.7 final drive??
Old Mar 20, 2012 | 05:35 PM
  #273
SDGenius's Avatar
please read, thanks
Old Mar 20, 2012 | 05:56 PM
  #274
Originally Posted by SDGenius
please read, thanks
so any 3.7 pumpkin from a 6mt should be a direct fit correct?
Old Mar 20, 2012 | 08:38 PM
  #275
herrschaft's Avatar
yes
Old Mar 20, 2012 | 08:48 PM
  #276
Found a 2008 g35 locking, AT 3.69 for 375$
how does this sound for direct fit in my 04 coupe g35 5AT
Old Mar 20, 2012 | 10:04 PM
  #277
Silencer_0's Avatar
It won't be a direct fit.
Old Mar 21, 2012 | 06:31 PM
  #278
bighapa's Avatar
the MT will have the same 4 bolt flange that your car has. I think the AT has 3 bolt flange.
Old Mar 25, 2012 | 05:24 AM
  #279
truexh's Avatar
Rear differential from 2009 g37 manual carry a 3.69 fd ratio correct guys? Do you guys know if it contain Vlsd or is it an open difff? Thanks In advance
Old Mar 25, 2012 | 11:48 AM
  #280
herrschaft's Avatar
It depends on whatever the FSM for that car says. Although www.infinitihelp.com was proven to have some wrong info, it can still be used as well.
Old Mar 26, 2012 | 12:29 AM
  #281
truexh's Avatar
whats FSM? But infinitihelp said its standard to have VLSD for 2009 g37 6MT. So am i able to buy this g37 rear diff without any concern?
Old Mar 26, 2012 | 12:48 AM
  #282
herrschaft's Avatar
FSM = factory service manual. And yes, that diff should mount up without modifying anything.
Old May 8, 2012 | 12:17 PM
  #283
Dani01c's Avatar
Man, it's really hard to find a 3.7 pumpkin from a manual g35-g37 in ebay :-/
Old May 10, 2012 | 11:08 PM
  #284
Dsskyline's Avatar
Go to car-parts.com search under carrier for a 07 G35.
Old Jul 11, 2012 | 03:55 PM
  #285
Mr.jay's Avatar
Originally Posted by boostedfox86
I just bought an 03 g35 sedan 5AT. I've learned that it has the 3.3 open diff. Do they sell a lower gear ratio for the open differentials? Preferrably a 4.08 ratio? Or would I have to change my whole diff case out for the LSD case to do a ring and pinion upgrade. Please someone help because this 3.3 ratio is a turtle from a hole shot
Hi i have the same case u had it before i need to change my differential coz it like turttle which one the best to buy and to give me high RPM?
