DIY 03 G35 Coupe 5AT to 07 G35S 5AT differential swap
Old Jun 18, 2017 | 09:11 PM
  #331
knghtryde's Avatar
Can Someone actually tell me what's required to Swap the G37 rear into the G35 rear. We have an 05 G35 Automatic and would love to do the swap, just don't know exactly what is required.
Old Jun 19, 2017 | 06:49 AM
  #332
Blue Dream's Avatar
I drove ttrank's car solo
Re-read this entire thread, the answers you seek are here...........
And no, we won't repeat them for you. It's one of the forum rules for members to search out answers to their questions before they ask for help.
Old Jun 6, 2020 | 08:32 PM
  #333
Yinster's Avatar
5 Year Member
just swapped a g37 3.7 diff with the flange swap to a 04 g35 auto, my slip light always flashing as soon as i hit 40mph, anyone may have idea on what went wrong?
i have already done search, disconnect my battery for the 3rd time in 2 days.......
i guess the worse case i have to do vdc delete
Old Aug 12, 2020 | 03:39 AM
  #334
xx7sephiroth7xx's Avatar
G
Need some help trying to confirm the diff I need.
I'd like to put together an upgraded pumpkin with 3.69 gears and an aftermarket LSD.
From my understanding, certain V36 sedans/coupes and 370Z's came from the factory with 3.69 gears, so I'd like to take advantage of this and hopefully find a pumpkin off of a low-mileage car, probably from a junkyard. (This graphic is helpful from Z1Motorsports: https://cdn.z1motorsports.com/upload...GearRatios.pdf).
I know I need to purchase an MT pumpkin so it has the correct flange (circular w/ 4 holes, as opposed to 3-tipped, 3-holed AT flange).
What I don't understand is whether I'll need to buy new stub axle(s) or whether I'll have to modify my stock ones. Is this dependent on the LSD I purchase?
Is anyone familiar with which stub axles come with open vs VLSD pumpkins?
Old Dec 26, 2021 | 07:59 PM
  #335
G
Well, I guess I'll answer myself because I think I know the answer now -- LSD can be purchased for your V35 or Z33 based on whether your pumpkin already has a VLSD or an open (or base) diff. Having a VLSD generally means you'll need to replace the RH output shaft with a shorter LH output shaft (Nissan PN 38220-AR011), but having an open diff negates this necessity.
The 3.3 FD found in V35 and Z33 automatic cars is 10mm thicker than the 3.5 (and up) FD. If you put a 3.5 FD into an auto pumpkin, it then essentially becomes an MT pumpkin. At that point, you'd need the VLSD from a 3.5 FD pumpkin or an aftermarket LSD to work with those gears; VLSD from a 3.3 FD will no longer fit. When looking to purchase aftermarket LSD, this is what AT vs MT specifies.
If you decide to go with a 3.7 FD from a V36 or Z34, if you keep your V35 or Z33 output shafts your CC should still work.
Old Dec 26, 2021 | 08:09 PM
  #336
cleric670's Avatar
BANNED!!!
Coupe 6MT Premium RAS
You don't even need to buy the short stub shaft, I just take a port-a-band and cut 1" off the end of the long ones and file the edge down to a slight bevel so it's not sharp and cutting the oil seal.
Tylertu29
V36 Engine, Exhaust, Drivetrain & FI
Jun 9, 2020 10:03 AM
cswlightning
Drivetrain
Dec 28, 2018 10:11 AM
Jdmay35x
Nov 7, 2014 08:10 PM
Jon81035
Apr 29, 2010 09:18 PM
migueralliart
Drivetrain
11
Nov 13, 2009 06:58 PM
