4.08 Gears
Old Apr 28, 2011 | 06:27 PM
eksigned's Avatar
4.08 Gears
I know there are quite a few threads on the topic, but I wasn't really able to confirm a few things. Would greatly appreciate if you gurus could throw out your 2 cents. Neverbonestock (myg37) claimed only a 200 rpm difference between his stock 3.69 gears and his 4.083 gears. Truth to this comment? I was told it was more like 600 rpms. Also, has anyone swapped out completely, rear diffs? I'm in the process of trying to swap rear diffs between my buddy's 08 Z (HR) and mine. His 4.08 gears have about 7k on them. Install was done right - no whining, etc.. I know the abs sensor harnesses are different (planning to swap), but any clue on if it'll bolt directly? I've read around that a G35 and 350Z are a direct swap, as are G35 to G37s.
By the way, can someone confirm that the vlsds in the Z are "better" than the ones in the G's? G37 sedan in particular?
Thanks in advance,
Eric
Old Apr 28, 2011 | 09:03 PM
Sylvan lake V35's Avatar
Same diff same vlsd in G35 vs 350z direct bolt in exact same vlsd i have ne er heard if they changed anything for theg37 besides the ratio. 200 rpm difference seems low but there should be calculations to figure it out try googling it and see.
Old Apr 29, 2011 | 12:23 AM
eksigned's Avatar
^ thanks for the confirmation man!
Old Apr 29, 2011 | 01:03 AM
Tollboothwilley's Avatar
3.69 to 4.08 wouldn't change more than 200-300 rpm
3.3 to 3.69 would be about the same
3.3 to 4.08 would probably change 450-500
only the 2007-2008 G35 Sedan was 3.69 stock, along with all 6MT G37s - these pumpkins can bolt up but need modification. Some people that have swapped pumpkins have lost Cruise Control, some have cruise only able to engage up to a specific speed (like me ~85mph), and some have had issues with speedometer being off after the swap.
There seems to be a correlation - but you should read up on in in the Drivetrain section
Old May 1, 2011 | 04:41 PM
eksigned's Avatar
^ thanks for the direction. i've done quite a bit of reading on the topic. i just CAN'T SEEM TO FIND what particularly modifications need to be done to do the swap successfully. a buddy of mine mentioned something about abs sensors?
eksigned's Avatar
my sensors split off into 2, while the Z's goes into one?
Old May 1, 2011 | 04:56 PM
ABS sensor on each side - no real difference
If you are swapping from a 2nd Gen G35 sedan (3.69) then the input shafts need to be swapped, thats about it.
G37 pumpkins may be more of a direct fit - minus the ABS sensors which just have a different connector. This is probably (also) the reason that the G37 pumpkins that have been swapped to the G35 have had issues with the speedometer.
Old May 1, 2011 | 07:09 PM
eksigned's Avatar
^ thanks for the info. hoping the abs sensor won't give us any problems. guess we'll find out within the next hour?
Old May 1, 2011 | 07:56 PM
i bet you will. Give it a nice test on the freeway. Make sure you have another car to verify speedometer is accurate.
Test your cruise control as well.
Old May 1, 2011 | 10:31 PM
eksigned's Avatar
Bah, we had to off put the install
I apologize for all the questions tooth, but believe me...your input is greatly appreciated! Anyway clue on how I should go about modifying the abs sensors? The friend I'm working with has a solution, but in case it doesn't work...I'd like to be able to "pretend" like I know as much as he does...lol
Old May 1, 2011 | 11:33 PM
just use the stock ABS sensors. Don't use the G37 sensors.
Old May 2, 2011 | 12:19 AM
eksigned's Avatar
The 08 Z has ABS sensors that merge off the pumpkin, into ONE. My G37 Sedan has two off the pumpkin that go into independent ports all together. Using the OE ABS sensors off the Z's pumpkin means one isn't receive input.
Well...I guess that might work? Unless the computer doesn't fix itself (doesn't see 2 inputs from one ABS sensor)... it might throw a code because the other isn't receiving a signal.
I don't really know what I'm talking about. Can you tell? lol thanks for your input man!
Thebaws11
Jul 2, 2021 11:36 AM
Since 1983
Sep 19, 2015 10:26 AM
FRUG35
Sep 11, 2015 03:07 PM
UndyingDest
Drivetrain
Sep 7, 2015 12:49 AM
pasjr1972
Sep 1, 2015 10:17 PM
