Check Engine and Small Leak Error
Old Jan 21, 2003 | 01:34 PM
VNT's Avatar
VNT
Re: Check Engine and Small Leak Error
What's the actual fault code?
With OBDII systems, when a fault code appears and the MIL appears also. What also happens is a "fault counter program", where over the next couple times you start and drive the car, if the same fault does not reappear in the OBDII computer, then the MIL light disappears, but the code remains in memory.
This may be what's happening.
Old Jan 21, 2003 | 03:32 PM
Msedanman's Avatar
O.F. Administrator
Did they have any idea what the "small leak" might have been?
I guess all you can do is make sure all fluid levels are ok, and that it seems to be running ok, and let them worry about the 'check engine' lights.
If there's any news or developements, let us know.
Gsedanman--in Silverstone Coupe clothing.
Old Jan 21, 2003 | 07:05 PM
Learn2Turn's Avatar
Was it an "EVAPS" related leak?
INFINITI
Service Consultant
Old Jan 21, 2003 | 07:37 PM
Msedanman's Avatar
O.F. Administrator
Tell us more , L2T, ..Is it possible it wasn't a 'conventional' leak but a polution control leak that would have triggered the 'light'?.... Also is it possible that the leak was temporary?
Any incite would be appreciated.
Old Jan 22, 2003 | 10:50 AM
Learn2Turn's Avatar
Any incite? Like a riot?
It is posible the "leak" can be a pollution control related code.
This is why I'm asking for the exact fault code, number and description. Without this info, you cannot proceed with theory
and diagnosis.
INFINITI
Service Consultant
Old Jan 22, 2003 | 10:21 PM
NJ2VA's Avatar
If the ECM detects the fault on 2 consecutive "test" cycles it will set the mil. What was the count? It is detecting a failure in the evaporative emission system. Usually a loose gas cap sets a "gross leak" code. Did they do a DTC confirmation test? Sometimes intermit. problems are very difficult to find/duplicate. Most CEL's are caused by a failure of the equipment/sensors used to check the emissions. While the engine/emissions are ok
99 Camaro SS
99 Grand Prix GTP(hers)
91 GMC Dually
72 Pro-Street Nova(tubbed and blown)
Old Jan 23, 2003 | 06:13 AM
Msedanman's Avatar
O.F. Administrator
Of course, LTT, excuse me for 'inciting' you .................... LOL
I asked you for an educated guess. Thought it might be interesting since there was limited info from the dealer. Your sig. told me that you may have had some 'insight'. Thanks......
Gsedanman--in Silverstone Coupe clothing.<P ID="edit"><FONT class="small"><EM>Edited by gsedanman on 01/23/03 03:22 AM.</EM></FONT></P>
Old Jan 23, 2003 | 08:07 AM
VNT's Avatar
VNT
To L2T's defense, there's hundreds of codes within the OBDII system, from the standard codes to manufacturer specific codes.
Without knowing with code which the OBDII computer stored, most technicians will just be guessing out of their asses.
There are technicians who will use the old fashioned way of diagnosing in addition to the convenience the OBD system offers.
Old Jan 23, 2003 | 03:46 PM
Msedanman's Avatar
O.F. Administrator
I hear ya. Sounds like problems like that are akin to locating a needle in a haystack. The "old fashioned way" probably takes too long and isn't cost effective, and I doubt that there are as many techs out there anymore that are as good with the Consult 2 as well as good at using that old fashioned way.
The price of progress I guess.
Old Jan 26, 2003 | 05:12 PM
Learn2Turn's Avatar
It is all fun with me so no offense shall ever be taken.
It's true, I can guess, as I have much experience as a technician and now represent Infiniti's service department.
Though an educated guess for others may be a blabber of the lips away, I have a responsibility to help resolve situations with facts, accumulated from all the resources accessable to me.(consult2+Infiniti master techs)
That's what Infiniti pays me for and what any client should expect. So cough up some diagnostic printouts or tighten your gas cap 'til your wrist snaps. HAH HAH
INFINITI
Service Consultant
Old Jan 26, 2003 | 06:16 PM
Msedanman's Avatar
O.F. Administrator
Wow, That's harsh. And I don't know where the 'attitude' is coming from, so please enlighten me if you can. and I didn't expect you to be offended because none was intended! So why are you? My point that you totally misread b4 was that finding or pinpointing problems on a car these days was akin "to finding a needle etc". No one's trying to minimize your experience and what you could accomplish so ease off on the 'bricks' please.You're reading way too much into my posts- OK. I'm a friendly and helpful kind of guy like a lot are around here and no one intentionally upsets anyone.
As far as coughing up diagnostic printouts are concerned- well, I'll leave that to experts like you, who have access to ,and as you've said, are paid to do.
In case you're wondering I've been around cars for some time myself and know a thing or 2 about mechanicals and electricals, so thanks in advance for recognizing that there are ppl around that know 'something' , even without a scanner in their hands.
Good luck with your job, and my hat's off to your knowledge which we all appreciate that you share with us. I'll be the first to say that at times I need help.
I'll go easy on the gas cap, thank you. Broken wrists would cut into my typing...HAHAHAHA [img]/w3timages/icons/smile.gif[/img]
If you feel the need to respond further to any of this, I ask you to take it to Private Mail. Thanks for listening. I look forward to your informative posts.
Gsedanman's Coupe
Old Jan 27, 2003 | 11:32 PM
mbarrad's Avatar
Hey, everyone deserves a second chance. Learn2Turn, with your expertise in Infinity service, can you tell me if it is easy to program the ECU to turn off the adaptive learning algorithm? Is Infinity going to offer new ECU maps that will increase performance and fuel economy? Can the transmission also be programmed for different (shorter) shift patterns? Glad that Infinity techs are paying attention, maybe you can help us out.
Limited Edition Twilight Blue / Premium / Graphite / Xenons
Muski_G
Dec 1, 2023 11:11 AM
Kng0fHrts
Sep 15, 2015 05:40 PM
Jay 21
Aug 5, 2015 04:53 PM
ClwMike
Jul 23, 2015 12:55 PM
Jadenkid22
Jul 14, 2015 12:33 AM
