UR Pulley worth it??
Old 03-31-2004 | 03:19 PM
Msedanman's Avatar
O.F. Administrator
Re: UR Pulley worth it??
Yes you do need new belts. I've just bought mine and have the numbers here:
Good Year Gatorbacks came highly recommended.
1/ #4060445 (44.5") - Crank, Alt., Water pump belt
2/ #4040350 (35.0") - A/C belt
<font color=red>GSM</font color=red>
<font color=black>Silverstone Coupe</font color=black>
  #47
Old 03-31-2004 | 08:55 PM
Coz@Czp's Avatar
Don't use the Gates recommended sizes, the 6 Rib is too big, and will cause squeaking, I actually sell the correct size Nissan belts w/ the pulley sets we sell.
www.czp.us
  #48
Old 03-31-2004 | 09:03 PM
mstil35's Avatar
Just received my Unorthodox Pulley from Coz today.....Having it put on tomorrow (my cousin owns a garage)Must commend Coz on his SUPERB customer service!!
  #49
Old 04-01-2004 | 07:53 PM
mstil35's Avatar
Got my UR Pulley installed today. HOLY S$^&!!! Could not believe the difference in pick-up. Could definetely tell using the butt dyno. A great mod for the price.
  #50
Old 04-01-2004 | 07:59 PM
Msedanman's Avatar
O.F. Administrator
Great to hear Mike. I'm still waiting on mine to come in. Should be this week.
  #51
Old 04-01-2004 | 08:07 PM
TWG35's Avatar
I got my UR Crank Pulley from Concept Z complete with the belts 2 weeks ago and it has been wonderful. No squealling, no mess, just quick acceleration whenever you want it. Highly recommend Concept Z for this mod. You will enjoy!
  #52
Old 04-14-2004 | 01:16 AM
alsfine's Avatar
I had the set installed in my '03 Sedan and have continually experienced a squeaking noise after 3 replacement belts and my second set of pulley's. No change, and will probably replace with stock set unless someone can offer a solution?
FYI: Have tried numerous attempts at tightening and grease.
  #53
Old 04-14-2004 | 03:23 PM
cinergi's Avatar
How much grease are u using? If you are using alot or get some where the belts are you will have squeaking. I used just a tiny bit around the center and have had no problems.
  #54
Old 04-14-2004 | 06:20 PM
al503's Avatar
Also, once you get the pulleys on, you want to make sure that you haven't put any greasy fingerprints on the outside of the pulleys where the belts will be. Wipe the pulleys down completely before installing the belts.
  #55
Old 04-15-2004 | 08:32 AM
SFLG35's Avatar
FGC President
gsm or anyone else with an auto: you have an auto right? did you get the crank pulley put on? does it help? worth it for the auto? thinkin about getting one but after readin the threads on here and my350z it seems like everyone has a 6mt. so far it seems that the benefit out weight the risk factor and the price isnt that bad either. thanks
Daniel
5ATc / DP / Premium / Aero / Clear Bra / 5% Tint - 30% Windshield / Ground Kit / Clear Corners / Shock Sensor / L.E.D. Hood Lights / Z - Tube / OEM Remote Window Up semi-fixed and installed
  #56
Old 04-16-2004 | 12:36 AM
alsfine's Avatar
Belts had been replaced once by Stillen and the second time they replaced the Pulley's as well. Still squeaks?
  #57
Old 04-18-2004 | 04:59 PM
nuttyprof's Avatar
"The Set doesn't do much more because the size of the additional pulleys are the same, and they are about .5 lbs less then stock. The Main Crank Pulley is where you get your Power Gain from. ASP pulleys are a replica to the UR pulleys, but they are heavier. And they also won't have the dampener on it."
Im just wondering where you got this info about the ASP's from? They should not be a replica of the UR pulleys. I personally sent them the stock pulley set, which they are working on. Despite the lag, that is what they are using as a blueprint and not the UR pulley set. As for weight, they are not created yet so there is no idea of what they will weigh. Dampener, they probably will not have as well as it is not necessary. I dont know where you got your info from, but if you would post that and verify your info that would be much appreciated. I have been waiting for details for awhile now.
G35S 6MT / ts ecu / 350z springs & struts / jwt popcharger + z-tube / stillen dual exhaust / 6-wire ground kit / soon: kinetix high flow / ssr intake manifold
  #58
Old 04-24-2004 | 05:17 PM
n1cK's Avatar
G35 6MT
a couple of install questions: what's the best way? did anyone use the method where they let the wrench hang from the bolt, then crank the engine (ever so slightly) to get the bolt to turn? that by the way, is the most dangerous, ha ha! or did you guys use a chain wrench to hold down the pulley, and then loosen the bolt (this can damage the pulley)? thanks!
n1cK
jUs' bE [img]/w3timages/icons/cool.gif[/img]
seagrasser
05-03-2022 09:43 AM
Mad A
Not G35 Related
12-08-2015 01:45 PM
NailBomb
10-28-2015 07:53 AM
Visionnn
10-03-2015 05:16 AM
G35-2004-mt6
09-11-2015 04:16 PM
Quick Reply: UR Pulley worth it??
