AFTERMARKET INTAKE OWNERS---READ ASAP
Old May 6, 2004 | 01:54 PM
  #31
GR8TG35's Avatar
Re: AFTERMARKET INTAKE OWNERS---READ ASAP
I'm no expert here, but I don't think you can patch the ac line...especially if its aluminum. The lines are usually under either high or low pressure depending on what side of the compressor its running........a weld shop may be able to weld it if they use argon gas or something similar for welding aluminum...
Otherwise, best bet is to have it replaced....but before you drive yourself nuts....make sure that is the problem and not something else.........
04 cpe IP/willow/5at/prem/18's/JDM clear corners/Piaa's/MTEC H4 Super White fog/highs
Old May 6, 2004 | 02:18 PM
  #32
iLLG35's Avatar
NY G-Squad G Race Driver
Gr8t ur rite, i just called up infiniti parts at smithtown dealer in NY and explained and he said the part is $58.32. Now I am relieved, but then he said it could be dried out if i dont get it done soon then ill need a new kompressor and everything i was like UMM lol. Anyway ill order the new line and get it put in I guess, then just wrap it up so it wont happen again. iLLG
Martin
2003.5 BS G35
Full Aero/Sport Package
Injen CAI
350Z Springs
Clear Corners
ADR M-Classic 19's Soon..
Old May 6, 2004 | 05:26 PM
  #33
Shader7's Avatar
I checked my Nismo CAI, and the aluminum adapter edge was slightly touching that very line. There's a bit more than a scratch in the line; no leak yet but I bet it would have soon. I moved the line a bit for now, and I'll look into a permanent fix.
You probably need to recharge the AC system after replacing that line, that's why it's such an expensive repair.
Good get.
Black/Willow 03.5 6MT, Premium, Navi, Aero, SAT
350Z Nismo CAI
Old May 6, 2004 | 06:40 PM
  #34
neffster's Avatar
OK, here's the original link that I could find that addressed this issue. It dates back to last month and was posted on Fresh Alloy.CAI kills A/C Line. It tells you how much the line and installation really cost (BTW it's not $800).
I checked my setup today and I saw that I have (had) the Z-Tube touching the A/C line. I re-bent the bar on the Z-Tube, no luck. I rotated the Z-Tube, no luck. I rotated the JWT Pop charger, no luck. I eventually loosened the bolt (with the black washer beneath it) that attaches the Z-Tube bracket to the plenum and slid the bracket as far away from the A/C line as possible. I gained about .125-.250" of clearance between the Z-Tube and the A/C line after adjusting this bracket. This is not enough clearance for me to feel comfortable and I'll attempt to make a more permanent fix tomorrow (day off yippiee!). Maybe a dremel tool and a few minutes opening up the hole on the black aluminum bracket and I "might" have all of the clearance that I'll ever need.
300bhp??? We'll see... 5-22-2004
Old May 6, 2004 | 06:50 PM
  #35
cato's Avatar
SouthernComfort Moderator
I checked mine when I got home from work. I have the Z-tube
coupled to the Stillen HFAB. There is a bunch of room
between the A/C line and the MAF tube. The Stillen couple
to the MAF tube prevents it from getting near the A/C line.
I cannot even push on the MAF tube to make it go closer
to the A/C line. It looks like the Stillen box is really well
designed. There is no way any part of the intake, stock or
Z tube, can come close to the A/C line. Whew! I knew I
spent $260 for a good product.
2003 TwBlue 5AT Sedan, sunroof,
Graphite Leather, splashguards, HKS exhaust,
14 wire Grounding kit, 350Z duct, Stillen CAI
Underbody rear diffusers, Drilled alum pedals
Old May 6, 2004 | 07:21 PM
  #36
docron1's Avatar
From: Centerburg, Ohio (the geographical center of the Buckeye State)
$260, you can get the Stillen CAB for $189 on stillen.com now......sorry.
Old May 6, 2004 | 07:27 PM
  #37
iLLG35's Avatar
500$ i would like to know for what. The AC line I was quoted $58.32 for and recharging should be $75 or so and labor like 100-150? I dont see 500 but im still very very pissed!! I dont have this money to put out because i just bought my new rims and stuff but now have to get this repaired wow im so heated. Whateva, ill just get it fixed i have no choice then put foam covering and stuff around it . iLLG
Martin
2003.5 BS G35
Injen CAI
350Z Springs
Clear Corners
Old May 6, 2004 | 07:41 PM
  #38
NYCG35's Avatar
G SQUAD
Guess it varies from car to car....
I did the "rotate the JWT" fix as posted earlier with the pics
and between that and bending the mounting bar some I got about 1/8 inch clearance...it was touching very slightly though when I checked it out....
Tested my A/C and all is well....
Great catch though.....!!
Lexus for my luxury and G35 Coupe for my speed. I must say...Life is not always a B!TCH
Old May 6, 2004 | 08:34 PM
  #39
matters's Avatar
does the a/c line still rub if you have a z-tube with the stock air box?
Old May 6, 2004 | 09:43 PM
  #40
DED's Avatar
DED
Neither rubs if it's installed right and you know what to look for. If you have to ask, you better check!!
2004 G35C 6MT Black. What Honey? I don't know where they came from. I came home and it was like that...
Old May 6, 2004 | 10:01 PM
  #41
Tory's Avatar
I just checked mine out and i only have the z-tube. I saw there were a couple scratches on the A/C line, but the distance between the line and the z-tube was a good 3/4", maybe i hit a bump or something. Its been hot here anyways, so i rapped the whole A/c line in insallation, so now i can have super cold A/C, and ill have no worries when i put my Stillen CAB in! I just wrapped the whole pipe in a bunch of different sections with some 5/8'' ID insalation, and in the gap between the A/C line and the z-tube i squeezed a piece in that i glued down around the sides. Ill check on it in a few days to see how its holding up!
2004 Sedan
Black/Willow
Premium w/ splash guards
Clear Corners, Z-tube
Old May 6, 2004 | 11:53 PM
  #42
DJames's Avatar
This happened to me .. i have the INJEN CAI and the MAF bolts rubbed againts the a/c line and i did not know that.. and so i tried using my a.c about 2 weeks ago and i was wondering why hot air was coming in so i took in to the dealership and they found the problem.. they wanted to charge me $700 to fix the line because they had to go through the firewall .. but i was like heck no ... cause i did not have the money because i am a student and i didnt want my parents to know that my aftermarket product avoided the warrenty so i took it to my uncles and he fixed just welded a piece here is couple pictures..
Old May 6, 2004 | 11:55 PM
  #43
DJames's Avatar
the welding doesnt look that clean but it work perfect and cant complain got it for free saved me $700
Old May 6, 2004 | 11:57 PM
  #44
DJames's Avatar
Old May 6, 2004 | 11:58 PM
  #45
DJames's Avatar
