stealthy Z tube.
Old Jul 16, 2004 | 02:25 PM
shodog's Avatar
stealthy Z tube.
I have been pondering the Z-tube Mod for my sedan. The only thing holding me back is the fact that once installed, you can tell that the intake has been modified. While my car is on warranty, I want to keep it stock as possible. This way there would be no problems with the warranty.
In looking at the Z tube, it just looks like it's a tube with a straight shot from the airbox to the intake. On my sedan the tube has the little box for what ever the reason. Couldn't you just take the stock sedan tube and line the inside with a thin tube of lexan that would bypass the box and essentially do the same thing that the Z-tube does?
Jim
'03.5 Sedan
Brilliant Silver/Graphite
6MT/ Premium package
Sport tuned suspension
Aerodynamic Body Kit
Navigation and Satellite Radio
Old Jul 16, 2004 | 02:35 PM
GRider35c's Avatar
Re: stealthy Z tube.
yes you can.
do you know that its called the Z-tube cause it comes stock on a nissan 350z??
i doubt this will void the warranty... dude, just replace it!
04 / BO / G / aero / splash / prem / perf / cc / 22%tint
z-tube / k&n drop-in / Eclipse AVN
Old Jul 16, 2004 | 03:03 PM
Raznips's Avatar
there are laws against voided warranty's by dealers because changing out ur ztube isnt going to affect anything. They wont care if u change it or not. The difference between ztube and stock gtube is that the gtube has sound boxes on top and bottom that quiet it down (and restrict airflow). its about a 10 minute replacement for the ztube alone if u keep ur stock airbox. Just unscrew maf, the screwn holding it to the plenum, disconect the tube attached under the ztube and unscrew and wiggle off the end connected to the plenum and then put the ztube on and do all those steps backwards. Its really easy. I installed p/c +ztube combo in about an hour and half (friend dropped a socket wrench down in the front bumper and that took about 30 minutes to get out, and the 4 pieces of rubber on the p/c tok about 20 minutes for me to get on there, and the rest was extrememly quick easy and painless. I would do it if i was u. I have no regreted it since the day i got it done.
2004 Black on Black g coupe 6spd.... aluminum pedals, clear corners, z tube, and pop charger. soon to have 19" volk gt-c's and PIAA xtreme whites in the clearance and corners
Houston Texas
Old Jul 16, 2004 | 03:05 PM
bsgoren's Avatar
1...it looks similar (although the Z tube doesn't have the resonator box which is what restricts the airflow I guess).
2...it's very easy to install and un-install and put your old stock intake back if & when the time comes.
3...I've been told that it shouldn't void the warranty (and if it did, it would only pertain to the intake itself which you replaced with a Nissan OEM stock part anyway and not the entire b-2-b or powertrain warranty).
4...it's definitely worth it!!!!!! ;-)
btw - my car has been in for service a few times since I 've had the Z tube and nobody in the service dept has mentioned a word about the Z tube or the K&N air filter I have in my car.
2004.5 G35-S 5AT Black/Willow - Prem, R. Spoiler, Navi, Infiniti Sport Wheels, Alum Pedals, Dark Tint, Z Tube, K&N Filter
Old Jul 16, 2004 | 03:12 PM
mai's Avatar
mai
What's wrong with taking a stock part form another car and putting it on your own? Especially if it's almost the same car. Our car has had service and they never said anything, you have nothing to be afraid of.
Old Jul 16, 2004 | 03:23 PM
bsgoren's Avatar
Mai -
Were you responding to me or shodog, the thread originator? That was one of my points -- there shouldn't be anything wrong with taking one Nissan/Infiniti intake tube (from our G35) and replacing it with another Nissan intake tube (from the 350Z). I too haven't had any issues with my Infintii service dept. and do not expect any problems; plus the fact that we're talking about an air intake tube...not exactly something that you would expect to have a failure or problem with. ;-)
Old Jul 16, 2004 | 04:41 PM
shodog's Avatar
You guys are probably right, most likely they wouldn't give me a hard time at the dealer. I guess it all depends on the dealer whether they wanted to be difficult or not. As others have said I could alway put the old tube back on if it goes in for service.
Jim
'03.5 Sedan
Old Jul 16, 2004 | 05:34 PM
KPierson's Avatar
Jim,
I think you will be very happy with the Z tube. I fell in love with it the first time I heard the car rev up with it installed.
Kevin
www.KPtechnologies.net
AIM: KPiersonTec
04 DG Coupe / VDC Memory
OEM Remote Window up mod
Procharged / Crawford / TS
Old Jul 16, 2004 | 08:20 PM
Raznips's Avatar
just so u know... ur car will run wihtout an intake tube at all.... so unless the airflow is cutoff or something it wont mess up ur car (i didnt say it would run WELL... just that it'll run)
Houston Texas
Old Jul 16, 2004 | 08:44 PM
G35Papa's Avatar
shodog
I have 42,000 miles on my G and have taken it in many a time for service and warranty stuff. Not once have they mentioned any of the mods I did to my G (Z tube included). Ive even taken it to two different dealers.
I to am very very happy with the sound (and a bit of a kick) the tube gave after the install and an ECU reset.
This mod is arguably the best bang for the buck.
In other words........GO FOR IT ALREADY! [img]/w3timages/icons/laugh.gif[/img]
G35papa
2003 Pearl White - Premium Willow - Clear Corners (moded) - Z-tube - 18" OEMs- Tinted all around
Old Jul 16, 2004 | 10:03 PM
KPierson's Avatar
The car will run without an intake tube, but not for very long most likely. As soon as some water, dirt, dust or rocks gets in the engine its over, as without an intake tube you will have no filter!
Kevin
AIM: KPiersonTec
G'duprideR6
Engine - Intake/Fuel
Apr 18, 2016 03:43 PM
Greenlawnracing
Feb 21, 2016 10:39 AM
yassy
Aug 11, 2015 09:31 PM
QuadCam
Florida G Club
19
Jun 19, 2005 10:03 AM
