Turbonetics ST install!!
#31
#32
![](http://htmlimg4.scribdassets.com/8b3aro9szklqvfx/images/16-94b7550ede/000.jpg)
That is the pic I looked at. It shows the adapter on the top. The last one.
"Install the injector adapters (Round aluminum part w/ 2 diameters; P/N 21211) onto the top of the new injectors with the larger diameter facing down towards the body of the injector (pointed out in FIGURE 25)"
That is how it is worded.
#33
#35
here are the parts! sucks i cant find my injector spacer!!!!
http://photos-e.ak.fbcdn.net/hphotos..._1627774_a.jpg
http://photos-a.ak.fbcdn.net/hphotos..._3376009_a.jpg
#36
#37
#38
#40
#41
good news. talked with turbonetics and the fuel injector adapters and spacers are going to be over nighted for free! here is the latest on the build
fuel pump done
http://sphotos.ak.fbcdn.net/hphotos-..._7918197_n.jpg
injectors started...
http://sphotos.ak.fbcdn.net/hphotos-..._8200959_n.jpg
power steering cooler relocated.
http://sphotos.ak.fbcdn.net/hphotos-...70_64019_n.jpg
ac line wrapped int heat wrap. 3 coats.
http://sphotos.ak.fbcdn.net/hphotos-..._5886497_n.jpg
fuel pump done
#42
#44
I just finished my TN install a couple of days ago. Let me tell you one thing, some parts will not fit as they should but you will have to make it work.
There was a big gap between Part# 21179 (Tube, MAF Sensor to Throttle Body) and Part # 21178 (Tube, Intercooler to MAF Sensor – 3). I had to use cut out a piece from the oem intake tube in order to close this gap.
Also, if you received the 440cc injectors this means you don't have the revup engine. If you do have the revup then you should have received the 600cc injectors.
One more thing, you should probably also buy coolant along with PS fluid and oil/filter. I found it easier to mount the turbo with the radiator fans and even with the radiator off.
Good luck to you and keep us updated!
