Turbonetics ST install!!
Thanks man.. Will be posting initial pics soon. Just got back from autozone and bought my ps fluid and oil. I'm also painting all the charge pipes gloss black. I will beatrting that now. The ones it came with were corroded. So I'm stripping it, reserfacing it, then paint... It's gonna look bling! As for the ac line. Couldn find it on import parts pro. So I'm just going to improvise something.
with the deatchwerk injectors you don't need spacers. They are exact OEM drop ins. The kit may have come with other injectors such as RC that needed a spacer, but the deatchwerk will fit fine
today, going to autostore to get a few bew coupler. the turbonetics couplers have a few holes in them so im replacing them. also getting a new air filter. hopefully i can start with the fuel pump and injectors later! more pics to come soon! BTW, my injectors are green and kinda small, i think those are the 440cc denso injectors that come with the kit? how would i get those spacers i need for them? what do they look like?
i mis lead you with the a/c line. you wont find it at importpartspro but the oilpan spacer is there and ant other parts you need for the vq. you will have to look elsewhere for the a/c line of you want to change it out.
you cant use washers... the spacers are just under an inch in length and slide around the injector like a sleeve. i can check my garage to see if i have any more lying around but im not sure. it would be more like small pieces of aluminum conduit. if you call denso they might be able to send you some.
#30
