What is intake valve timing solenoid
Old Apr 3, 2012 | 05:01 PM
Nortex's Avatar
What is it? Mine is bad, what are the ill effects of it? How do I replace it
Old Apr 3, 2012 | 07:33 PM
HotRodG35's Avatar
I believe your referring to the Intake camshaft positioner located on top of front camshaft bearing cap very visible between valve cover and timing chain cover.
Old Apr 3, 2012 | 08:24 PM
Nortex's Avatar
maybe lol. I just know the shop pulled the code and my check engine light is on
Old Apr 4, 2012 | 02:23 PM
Nortex's Avatar
What are the ill effcts. How importeant is it that I do it
Old Apr 4, 2012 | 04:19 PM
HotRodG35's Avatar
It will have a minor affect on acceleration and mid-high RPM power.
Old Apr 5, 2012 | 10:27 AM
Nortex's Avatar
Do I have to get it from infiniti?
Old Apr 5, 2012 | 11:18 AM
Rich@GRUBBS's Avatar
PREMIUM SPONSOR
It's different from the Camshaft Position Sensor,
there is a LH and RH side $195 shipped each side
here is an attached diagram to show them, this is for 2003-2005 G35 if you want more specific break down and part number go to grubbsinfinitiparts.com and put your VIN number in the system and you can get the one your car calls for sure,
check out this diagram, in the upper left hand corner is your Timing Valve Solenoids
http://grubbsinfinitiparts.com/nissa...&illust_seq=01
Old Apr 5, 2012 | 12:22 PM
Nortex's Avatar
Thank you phill how soon would I need to replace them
Old Apr 5, 2012 | 12:39 PM
PREMIUM SPONSOR
Soon as the light comes on
there's no real set "time" on how soon you have to replace it, the sooner the better to resolve the condition.
Old May 2, 2012 | 03:04 PM
Nortex's Avatar
Could someone actually show me this part. Im to dumb to read that diagram
Old May 2, 2012 | 10:03 PM
k67p67's Avatar
Upper left portion of diagram. Part numbers 23796 and 23796A. $170 per side + shipping.
Old May 3, 2012 | 02:38 AM
Tolboothwilley™'s Avatar
This can cause lower gas mileage and loss of power due to improper timing changes due to cam position. These solenoids communicate with the cam phase sensors to tell ecu what position cams are in and what to do
Old Jun 25, 2012 | 02:05 PM
Nortex's Avatar
Can I tell which is bad withut replacing both sides.
Old Jul 8, 2012 | 12:44 AM
G35_DAN's Avatar
Check your engine oil level...if it is low, this DTC will be stored. These solenoids work with oil pressure, so if the engine oil level is low, they will not do what the ECM tells them to do at different speed intervals.
Muski_G
Dec 1, 2023 11:11 AM
ghost_g35
Aug 7, 2015 10:31 AM
KevinnnVo
Jul 28, 2015 06:29 PM
lemmy999
Jul 25, 2015 12:13 PM
quickspeed6
24
Jul 15, 2015 11:06 AM
