Easy Ecu Resetting
Old Dec 13, 2006 | 03:17 PM
  #331
louisdarke's Avatar
when i try the disconnect battery for 15 minutes-- with the brake pedal method, to reset my ecu, i can't turn the ignition to "on" with the battery disconnected, so that i can depress the brake pedal with it in the "on " position. am i missing something? i have the intelligent key feature, if that matters.
Old Dec 15, 2006 | 01:59 PM
  #332
fortified's Avatar
Does nothing if you can't depress the pedal with the ignition in the ON position.
Alternatively, you can leave the battery disconnected over night.
Or just not worry about. The ECU should adjust over time, assuming we are talking about a relatively minor change.
Old Jan 3, 2007 | 10:00 AM
  #333
beholder's Avatar
Will this process work for a 2006 G35 6MT? Will the battery disconnect work? I have just given my car its first oil change and it feels like a fat pig. The tune is definately in Granny mode. When I floor it the thing doesn't even move until it gets over that initial build up of power but by that time the other car is gone.
Old Jan 3, 2007 | 11:40 AM
  #334
ISMSOLUTIONS's Avatar
Yes - they both work...
Old Jan 3, 2007 | 11:58 AM
  #335
gary c's Avatar
ECU Resetting.................
This is almost a joke.......it's like people can't read or comprehend what
there seeing. On page one you tell them how to and the very first post
asks a stupid question you've already answered. In the begining maybe
you should have told them to pull the negative side of the battery cable
and leave it off for an hour....then reattach.....then someone would ask
"how tight"............doooooooow
Old Jan 11, 2007 | 11:32 PM
  #336
G-Ride Canada's Avatar
Why don't we just have a complet method of how to refresh the ECU?
someone?
Old Jan 12, 2007 | 11:50 AM
  #337
someone?
Been there - done that...MANY times...
Old Jan 12, 2007 | 04:48 PM
  #338
Ya, I actually saw the post of yours, website of technosquare, gonna give it a try. but i just thought it would benefit other member to sum up the methods
Old Feb 17, 2007 | 01:08 AM
  #339
met722's Avatar
Worked for me. Not sure if it made any difference or not.
Old Apr 19, 2007 | 01:28 PM
  #340
pp7's Avatar
pp7
Does resetting the ECU make any difference to anything if you always use the manumatic mode on an '05 sedan?
Old May 20, 2007 | 08:10 PM
  #341
Red_G35's Avatar
On my other car I could just pull the fuse to the computer to reset it. Will that not work/not appy on the G35?
Old May 20, 2007 | 08:48 PM
  #342
Msedanman's Avatar
O.F. Administrator
Yes.......
C.
Old May 20, 2007 | 08:50 PM
  #343
Msedanman's Avatar
O.F. Administrator
No info on that.
The only methods I know of are to do the pedal type reset and the battery disconnect type reset.
Colin.
Old May 21, 2007 | 01:18 AM
  #344
There isn't a dedicated fuse for the ECU - it is shared by other components, but I don't know which off hand. It also uses a reverse loop ground, and that's why removing the the negative battery terminal works best, as all ground is lost and the loop will terminate.
Rick
Old May 22, 2007 | 02:29 AM
  #345
Red_G35's Avatar
I see, thanks for the reply guys!
