Catchin' Oil
Originally Posted by andy2434
Dang you, DaveO . . . Look what you got me involved in here.
. . . I love this stuff!
DaveO
Originally Posted by g35rcr
Hey Andy how long do you think that filter element is good for?
Originally Posted by DaveO
Ya', what a great job you're doing Andy! Your questions and responses are logicial and straight forward. You also remember what been posted previously... a trait that not all possess.
DaveO
DaveO
As you can see, this issue is quite real for me . . . And as such, I need to better examine what and why things are happening. You and the rest of the members' inputs and comments, are the reason(s) why I am pursuing this issue in the manner which I am. It's truly a "Community" effort.
small question, is the canister you all are using made out of glass? and is there any larger version of it wherever you guys are getting it? I'm imagining that a wider opening (not necessarily taller) would work better because it allows for the gas vapors to expand in a larger volume before being pushed along the path, allowing more time for oil to collect.
The bowl is acrylic--plastic.
Larger volume, cooler area = better separation.
As I previously stated, I view this is filter as a temporary set-up until someone builds a G35 specific oil catch device.
DaveO
I have searched most of the day to find the right components to fabricate a G35 friendly size canister, but everything available is simply too large for an easy install.
I just posted pics of the accumulated oil, which collected today.
Russ, I like your bowl placement. Prior to viewing this thread, I drew up a bracket of sorts and plan to fabricate it with a few extra goodies. I plan to mount this bracket at the Power Steering Fluid bracket, as you have.
I am anxious to see your catch bowl after a few hard miles of driving.
Here's my level after 250 miles of high speed driving.
Edit: Please include the type and weight of oil in your posts of this type. This was with Mobile 1 5W-30.
DaveO
DaveO
My car must be a freak.......
Now with 27K miles on her.....boosted w/ Vortech.....I can't tell that I use even a drop of oil between 4K changes.
I installed a catch can on top of my intercooler when I installed the SC, and hooked it up the same was as described here.
I can't see any oil in the lines or in the view tube on the can.
Oh well, knock on wood.....car is running GREAT!
