Makeshift Oil Catch Can
Old Jun 22, 2010 | 12:16 AM
  #226
Valgar's Avatar
Thanks for the DIY, I got the parts from home depot ( fittings and filter ) and advanced auto ( fuel hose and clamps )
Will install tomorrow, and report on the results!
Old Jun 23, 2010 | 12:04 AM
  #227
Valgar's Avatar
Here is my install! I got an Husky brand Air compressor filter from Home Depot, along with Teflon tape, and the barbed fittings. I got 18 inch long 3/8” fuel injection hose and clamps from Advanced Auto parts
As you can see from the pics, I discovered an easy spot to set the filter in to keep it in place and from moving around. I have an 06 coupe, so I am not sure if the bracket is the same in other models.
The catch can slides right into this stock bracket and slides right out when you want to check or change it. You do have no be careful to keep the filter level so no oil makes its way into the tubes when sliding it in and out though.
To get this fitment of the catch can in my engine bay, I took off the stock hose, and swapped the ends ( so the end of the hose that was connected into the lower collector is now connected into the engine block, and the end that was connect to the engine block is now connected to the "in" port on the catch can )
I then cut a few inches off the fuel injection hose, so it was between 14-16", and ran that hose from the "out" port of the catch can to the lower collector.
Old Jun 23, 2010 | 07:47 AM
  #228
UR2EZ's Avatar
That "valve" at the bottom of the filter leaks, you'll need to remove it with an Allen wrench and plug the hole (rubber stopper works great)
Old Jun 23, 2010 | 10:31 AM
  #229
Valgar's Avatar
Thanks for the tip! can you recommended what style/size rubber stopper fits this filter?
Thanks
Old Jun 23, 2010 | 04:24 PM
  #230
UR2EZ's Avatar
yeah actually i can
i got this one at home depot, in the aisle that has all the nuts & bolts in drawers.
Old Sep 5, 2010 | 06:21 PM
  #231
Ketchup83se01's Avatar
Are you guys collecting a lot of oil in them?
Old Sep 6, 2010 | 03:22 PM
  #232
Valgar's Avatar
Yeah, mine catches a good amount. Ever few hundred miles or so there is about an inch of oil in the can
Old Oct 9, 2010 | 08:13 PM
  #233
alexh521's Avatar
im scared...My car has 115k and i dont have a catch can
Old Nov 13, 2010 | 10:25 PM
  #234
jon121587@yahoo's Avatar
Just wondering if excessive oil is bieng passed through the home depot catch can could be eliminated by installing a second home depot catch can maybe??? i was thinking of purchasing another catch can and just extending the hose to add the secound catch can. Any Opinions. I kno it sounds funny but it can be preventing the excessive oil bieng passed through.
Old Nov 14, 2010 | 10:33 AM
  #235
V35 Skyline GT's Avatar
6MT Coupe
^Two cans plumbed in series can't hurt. If the hose from can to plenum is still oily inside, then the one can isn't doing the job well enough.
Old Nov 14, 2010 | 04:09 PM
  #236
Yea thats wat i was thinking so im going to add another one. wont hurt to try
Old Nov 14, 2010 | 06:34 PM
  #237
ShaneH85's Avatar
I just picked up 2 catch cans and will install them tonight. Ill post tomorrow after work if oil is in both
Old Nov 14, 2010 | 09:56 PM
  #238
Alright right on Like to hear the results
Old Nov 15, 2010 | 09:29 AM
  #239
ShaneH85's Avatar
well guys i put my 2nd catch in last night, same as the first one a husky from home depot, i have put about 65 miles on it and the first one has a cm or so of oil in it. And there is traces of oil in the 2nd, I'm going to leave it on and watch it over the next week. Ill have to get the plugs though to stop up the bottoms.
Old Nov 15, 2010 | 05:17 PM
  #240
I noticed On my single home depot setup that the hose going into the manifold had residue meaning that the excessive oil was bieng passed through. So maybe you can check if there is residue left with the two catch cans you have setup And let us knowwhat u find.
You have already rated this thread Rating: Thread Rating: 7 votes, 5.00 average.
