FAQ & DIY Frequently Asked Questions & Do It Yourself- Sedan and Coupe. Updates Approved by Administrators and Moderators.
Hyper-Ground (Earthing) Kit Resource Thread
Old Jul 16, 2003 | 08:31 AM
  #241
SixFive's Avatar
Re: Hyper-Ground (Earthing) Kit Resource Thread
Wait and see - if they get the word they may change production standard or process
Old Jul 16, 2003 | 11:31 AM
  #242
wooish's Avatar
GG:
I didn't notice anything else except smoother acceleration and engine more responsive. I also think the light is a little brighter. I was hoping to get more mpg.
Old Jul 16, 2003 | 02:16 PM
  #243
Gordgee's Avatar
Administrator
Cato:
I have the kit developed for the 2002/2003 Max / Altima / I35. Sorry, I'm not an expert on model year changes. Is the 2000 Max the same? PM me and we can work out measurements. etc.
<font color=green>GG</font color=green>
Old Jul 16, 2003 | 11:11 PM
  #244
wooish's Avatar
Here's the pic of my grounding kit installed on the Altima
David
<P ID="edit"><FONT class="small"><EM>Edited by wooish on 07/16/03 08:13 PM.</EM></FONT></P>
Old Jul 16, 2003 | 11:35 PM
  #245
Gordgee's Avatar
Administrator
Wooish:
You should move both sets of factory ground wires that attach to the top of the cam housing (pt. #2) to the same as the bolt holding the Hyper-Ground wires. It makes sense to ensure that all factory components fed by the ground signal are benefitted by the Hyper-Grounds.
<font color=blue>For those of you that have installed my G35 kit, please connect both sets of factory ground wires at the front of the engine to the same point connecting the Hyper-Ground wires. Thanks to slinkyboi5 for identifying the components grounded by these wires. I believe that you may notice some further changes in your engine response once you do this. Please post your impessions if you do. I did this and have also added an 8th wire to my G, so I'm not sure which is responsible for the changes I notice!
Old Jul 17, 2003 | 08:44 AM
  #246
slinkyboi5's Avatar
Gord ... I tried two ways.
1) Both factory grounds and all of your ground wires on one point.
2) I tried it with the factory grounds at their separate stock points with 2 of your ground wires on each.
The two methods above both are an improvement over all your wires on one point and the factory grounds on their stock separate points.
The improvement I noted from this improved arrangement is smoother shifting and a smoother start (which makes sense, since the ignition coil is one of the grounds affected). Did you see these two specific things?
Old Jul 17, 2003 | 01:37 PM
  #247
Gordgee's Avatar
Administrator
slinkyboi5:
So, to clarify, the arrangement you found the best was with both sets of factory ground wires connected to the Hyper-Ground cluster (all wires to the same point)? I'm going to reserve my observations until others try it and provide feedback.
Old Jul 17, 2003 | 02:05 PM
  #248
slinkyboi5's Avatar
I found that methods 1 and 2 (from previous post) were both about the same improvement over leaving one of the factory grounds by itself.
Old Jul 17, 2003 | 02:21 PM
  #249
dkle99's Avatar
This is getting confusing!
If you use method one which is 1) Both factory grounds and all of your ground wires on one point, which is what Gord has been suggesting. Then you can't use method 2. You can only use 1 of 2 methods, right? If this is correct, when you suggest that two methods (perhaps using together) is an improvement over method 1? I don't get...
Can you take some pictures? I'm going to receive my wires from z-xtreme today and will install tonight.
Old Jul 17, 2003 | 02:23 PM
  #250
slinkyboi5's Avatar
I'm sorry to confuse, what I'm saying is that I tried it with both those methods. You CAN'T do them at the same time. I tried method 1, went for a 10 mile drive. Switched to method 2, went for the same 10 mile drive, etc.
Old Jul 17, 2003 | 05:53 PM
  #251
Gordgee's Avatar
Administrator
I think the easiest and what makes the most sense to me is what I've already posted. All wires to one point, thereby ensuring a continuous Hyper-Ground path to the majority of vehicle electrical components.
Old Jul 18, 2003 | 11:55 AM
  #252
uclajeff's Avatar
Well, yesterday I went and reconnected the front ground wires. I tried it first the 2:2 way, except I have the 5 wire kit and there's only 3 wires going to the front engine so it's 1:2.
I noticed a difference not in starting up but just driving around - overall engine smoothness.
I guess I'll try moving them all to one point later today or this weekend and see if that makes any further improvment.
Old Jul 18, 2003 | 03:00 PM
  #253
brooch's Avatar
Hi Gord,
How about adding this thread to the DIY section with pics of the install and what hardware is required? I was thinking if u edited it in that section, there would be no redundancy when
looking for info. There is so much stuff in this thread, I find it
hard to go back and forth. I think the members would really
appreciate this, I know I would. Thanks for all the info.
Brooch
My G is absolutely "Mavelus"!
Old Jul 18, 2003 | 04:01 PM
  #254
Gordgee's Avatar
Administrator
Sure, good idea, I'll do it when I get the chance. I'm keeping this thread as is for feedback as well, which I feel is valuable. I'd like everyone will continue to contribute feedback here regardless of where they source their Earthing Kits and am especially interested in how these things perform on non-G35s.
Old Jul 20, 2003 | 09:26 PM
  #255
TheG35Guy's Avatar
Much ado about nothing...go buy some amp power cable and do this yourself for like $20.
I doubt you even need to upgrade your stock system unless you have some massive stereo upgrade. You won't make power with this mod unless you have such a crappy stock ground you're losing power.
Dan Parmelee
2003 Infiniti G35 Sedan
1999 Acura Integra GS-R coupe
2001 Infiniti I30t
