How to not grenade my tranny when going FI?
Old Jan 7, 2008 | 09:23 PM
G37Rider92649's Avatar
Red face How to not grenade my tranny when going FI?
Putting on a supercharger, and one of the mechanics was warning me about he doesnt know if my transmission can stand it, i did buy a tranny cooler but i dont know if it helps much, is there anything else that i can do? Or am i being over paranoid and ill be fine, let me know your opinion and advice guys. Thanks!!!!
Old Jan 7, 2008 | 09:45 PM
AGThing1227's Avatar
You will be good as long as you get it tuned right. Try not to go over 400HP or anything crazy. I would recommend a tranny temp gauge. You can get a VB(valve body?) upgrade but that is made so it withstands alot more.
-AGThing1227
Old Jan 7, 2008 | 11:34 PM
Xblackg35X's Avatar
my tranny is good! with no tranny cooler
Old Jan 7, 2008 | 11:35 PM
urban's Avatar
You should be fine, I was pushing over 400 with the Vortech and my tranny held up fine but long term the best thing to do is get a VB and TC upgrade along with the oil cooler and tranny cooler.
That is if you decide to go higher than 400rwhp.
EDIT: Def. get the L-spec flash to raise the rev. limiter to 7100 or your going to keep hitting the limiter, the stock shifts are way to slow once the Vortech kicks in.
Old Jan 7, 2008 | 11:39 PM
Skaterbasist's Avatar
Retired SuperMod
-AGThing1227
As long as the car is tuned to have conservative numbers (sub-400's as a reference), its not really going to affect the tranny on a 5AT. 6MT in the other hand, can handle more power.
If you're staying with a stock engine block, then I would say its the engine being the bottle neck, not the tranny. There's a bigger chance that your engine says bye than your tranny.
I wouldn't worry about it too much if I were you, especially with an SC.
Old Jan 7, 2008 | 11:47 PM
urban's Avatar
Originally Posted by skaterbasist
Tune is not going to affect the tranny. (It affects whether or not your engine does wave bye are you though )
Actually the engine if tuned correctly will easily handle what the Vortech can produce, I was pushing 440rwhp with my Vortech and then engine was fine for 41,000 miles, it's the tranny that started slipping.
George at GTM drove his G35 with 550hp on the stock block before it blew with abuse at the track, our engines are pretty good. The 5AT tranny will not handle anywhere that much.
http://www.my350z.com/forum/showthread.php?t=250645
Old Jan 7, 2008 | 11:48 PM
SDGeneralCounsel's Avatar
haha, what does the block being stock have to do with anything. As soon as you add power you are affecting transmission. A tune will affect at what levels boost peaks, which could be detrimental to your transmission but because the OP is using a sc, this shouldn't be an issue either.
Also a VB upgrade to my knowledge does not strengthen the transmission, it just gives you faster, crisper shifts. I would however recommend a tranny cooler. There are also 2 companies that I am aware of that do 5AT rebuilds good for 600 hp, but you shouldn't need that with a simple procharger kit.
Old Jan 7, 2008 | 11:55 PM
urban's Avatar
Nobody with a SC should need a full tranny build unless their names are booger or sentry...lol
Old Jan 8, 2008 | 03:10 AM
Retired SuperMod
What I was saying is, assuming most people going FI on the stock block will be keeping it at a safe level, they will probably not have any issues with the tranny.
urban, you're right about the 5AT not handling big numbers. I would definately do upgrades to the tranny if going over 400WHP (just as a reference number). On the 6MT in the other hand, I don't plan on doing any significant tranny upgrades while pushing over 400 whp.
Old Jan 8, 2008 | 03:24 PM
SIN3's Avatar
low 400s 60k on car 50k on blower (vortech) stock tranny.
good luck!
Old Jan 8, 2008 | 03:42 PM
617G's Avatar
CFW (Carbon Fiber Whore)
wow, so much missinformation in this thread.
1. The stock tranny is only meant to handle ~330 tq. WHP is only a measure of tq and has nothing to do with the tranny. The tq the Procharger puts out will put you at the limit of the stock tranny
2. You will notice your shifts get notchy and bumpy and this is a result of the VB sliding across the gears, thus creating more heat and wear and tear on the tranny
3. The tq converter can also only handle so much and will also begin to wear
4. Althought you will "probably" be okay, an upgraded VB will prevent the sliding across the gears, and the tranny cooler you already have will help dissipate the extra heat from the upgraded VB
peace of mind > $1,500
FWIW, I just about blew my tranny with the Vortech and it was on it's last leg. When I put the twins in, it was all over. It also has a lot to do with the way you drive. If you beat the **** out of it, which most new FI owners do the first few months, your tranny will suffer. Don't make the same mistake as myself and othe members have already made.
Old Jan 8, 2008 | 03:50 PM
617G's Avatar
Plenty of people have blown their trannys on "stock block"
400whp on a turbo car and 400whp on a CSC car are two different things. The turbo car will put out ~400tq at a low rpm, while the CSC car will put out ~330tq. Try going WOT in a turbo car in a stock 5AT tranny and I guarantee you will blow it within 6 months
Old Jan 8, 2008 | 04:24 PM
So best suggestion is VB Upgrade + Tranny Cooler and i should be ok? I was thinking of getting a VB Upgrade from Stillen, because they're in SoCal and 15-20 minutes away from me, what you guys think? I heard GTM and SGP would do better but they are a little further especially sgp.
Old Jan 8, 2008 | 05:23 PM
Retired SuperMod
If you read the original post you would know he has a supercharger.
Wear & Tear is greater on the tranny with any sort of FI, so it will definately take more of a beating than an NA VQ.
Show me how many supercharged VQ's have blown their tranny (without being driver error or from years of W&T/abuse). Not many
PS. If I had an auto tranny, whether its turbo or sc, I would still do some necessary upgrades for peace of mind.
Old Jan 8, 2008 | 05:55 PM
superchargedg's Avatar
Do not waist your money on the stillen vb as it is just barely better then stock.Go with either the gtm or sgp vb and a nice trans cooler and you should be fine with the s/c.
