Well My FI Days Have Come To An End.....
Old Apr 21, 2008 | 11:04 PM
  #226
BeerViper's Avatar
Most of the DIY's I saw are for the passenger side. One of the pics in the homemade catch can threads showed someone that used hose barbs big enough for the drivers side vent (5/8" hose instead of 3/8"). That's all I did was use a 5/8" hose barb reducer to fit the 1/4" threads of the air compressor filter. I installed the catch right before it goes into the filter on my Vortech setup.
Old Apr 22, 2008 | 09:24 AM
  #227
waijai's Avatar
i.love.gold
Originally Posted by g35man04
I had the ARC vers 1 on my passenger side and when I removed it after 1500 miles...not one thing of oil had gone into it...it was dry.
It wasn't installed properly then. I had oil in my catch can within a few days after installation.
Old Apr 22, 2008 | 09:52 AM
  #228
g35man04's Avatar
CLUB MODERATOR
well damn....who knows then.
Old Apr 26, 2008 | 11:14 AM
  #229
rockd's Avatar
Originally Posted by exagorazo
Sorry if I missed the info somewhere, but was the engine OEM or rebuilt with forged internals? Thanks.
stock engine, stock internals
Old Apr 26, 2008 | 12:33 PM
  #230
g35man04's Avatar
CLUB MODERATOR
yup stick engine.
Old May 2, 2008 | 02:39 AM
  #231
G37Rider92649's Avatar
any updates?
Old May 2, 2008 | 10:33 AM
  #232
g35man04's Avatar
CLUB MODERATOR
I got the car back and it is at the house right now! running good! I have a couple of issues that I posted up trying to get some responses back about why my transmission is doing what it is doing...here is the thread.
https://g35driver.com/forums/g35-coupe-v35-2003-07/218525-got-car-back-today-couple-questions.html
Old May 2, 2008 | 10:46 AM
  #233
exagorazo's Avatar
What did the replacement engine cost and how much was the labor to pull the original and install the new one?
Why didn't you look into having a forged internals short block installed after the engine blew? Were the heads damaged too or would it have taken too long or were there just other issues with FI that you wanted to leave behind?
Old May 2, 2008 | 11:16 AM
  #234
BeerViper's Avatar
exagorazo ... the answers to your questions are in this thread. I know it's a long thread but everything is here, just search the thread.
Old Jun 21, 2008 | 04:50 PM
  #235
g35man04's Avatar
CLUB MODERATOR
well here are somre more pics of the actual engine after having it removed..
anyways majority of you know that I blew my engine but here are the pics that I could finally get....pretty nice holes!! The engine from above...still looks okay! the bottom now.
The good stuff!
Old Jun 21, 2008 | 04:55 PM
  #236
2drwild's Avatar
besides gas prices and cost of FI this is why I decided not to go FI..I can't keep my foot out of her and I can't afford to get another engine. Hope all your issues get resolved man...Sorry to hear of this misfortune..
Old Jun 21, 2008 | 05:44 PM
  #237
g35man04's Avatar
CLUB MODERATOR
yeah I am good to go now....just alittle issues electrically right now..I have the optima yellow top and my car has been dying for a little over a month now....I come home now and just put it on a charger the whole time...
Infiniti is running a test on it over the weekend to see if they can pin-point where the issue is...when I disconnected the negative terminal and plug that light tester up to it...what I did was clipped one end of the tool to the negative wire and touched the negative terminal and if this tool lights up then that means some is running when the car is turned off...sure enough as soon as I touched it lit up...so I dont know..
I have tested both the OPtima and alternator and both turned out okay..the batteries cranking amps were alittle low but not enough to prevent the car from starting.
Old Jun 21, 2008 | 06:09 PM
  #238
superchargedg's Avatar
When you are doing a electrical draw test like that you can find the circuit that its coming from by pulling fuses.When you find the fuse that turns off the light then you can check that cicuit for the drain.
Old Jun 21, 2008 | 08:03 PM
  #239
Julian's Avatar
The description you gave are consistant with an oil starvation related failure. The clacking sound you heard was the rod bearing spinning then it most likely seized on the crank and snapped the rod on the upstroke..How often did you check or change your oil?
Old Jun 22, 2008 | 12:11 AM
  #240
g35man04's Avatar
CLUB MODERATOR
I had an JWT oil pan spacer in there....I changed my oil at least every 2000 miles..The funny thing is that I had Infiniti Change my oil the week before it blew....I brought that up but they said it was all because of my procharger...I am wanting to pull the engine apart and see what I can find.
