Well My FI Days Have Come To An End.....
Old Apr 21, 2008 | 11:08 AM
  #211
g35man04's Avatar
CLUB MODERATOR
yeah I was never told when I picked up the car to never not run over 5500rpms if that was a danger zone......
Old Apr 21, 2008 | 12:29 PM
  #212
BeerViper's Avatar
Originally Posted by g35man04
Here is what my suprise was when I pulled off the plenums...
Hey Chris, just so you know ... I removed my upper plenum this weekend to clean it out and mine looked just about as bad as your (minus the coolant).
I installed dual catch cans for this reason because the addition of FI makes the oil vapor blow-by intensified 10-fold. Now that you're going back to stock I don't think it's as much of an issue but I would still recommend a catch can at least on the passenger side instead of letting it collect in the "lower collector" as Nissan intended and then being burnt in the combustion chamber.
I can't believe I waited this long to do this, I had so much oil blow-by coming through my plenum spacer I had to do something. I will post up pictures elsewhere of what I found...
Old Apr 21, 2008 | 12:54 PM
  #213
g35man04's Avatar
CLUB MODERATOR
well thanks beer! I am looking into something like this..
but its only made for the VQ35HR motor's only! boohoo...should of just upgraded to that...
http://my350z.com/forum/showthread.p...ferrerid=95346
Old Apr 21, 2008 | 01:05 PM
  #214
BeerViper's Avatar
Interesting, those ARC catch cans are super pricey but they are pretty!
Well I just did a Top Speed catch can on the passenger side and then did the home made DIY catch can on the drivers side (using an air compressor filter unit). I've already caught some oil after driving only 10 - 20 miles!! That's oil that had been recirculated back into the intake for 34k boosted miles!
Old Apr 21, 2008 | 02:01 PM
  #215
express705's Avatar
what do you mean a catch can on pax/driver side?
i have 1 catch can..
Old Apr 21, 2008 | 02:15 PM
  #216
sc00byd00's Avatar
NY G SQUAD
Maybe this engine can replace yours?
Maybe you can get in touch with this guy for an organ transplant. Hate to see one of our G's die.
https://g35driver.com/forums/archived-sales/193323-re-2003-g35-engine-w-28k-mile-very-clean-1400-local.html
  #217
g35man04's Avatar
CLUB MODERATOR
I had the ARC vers 1 on my passenger side and when I removed it after 1500 miles...not one thing of oil had gone into it...it was dry.
Old Apr 21, 2008 | 02:41 PM
  #218
BeerViper's Avatar
There is a valve cover vent on both sides, the passenger side is directed back into the lower plenum, the drivers side is directed into the intake. Here are some links for ya...
Catchin' Oil
Homemade Catch Can
Makeshift Oil Catch Can
Sorry to derail your thread G35Man04
Old Apr 21, 2008 | 02:43 PM
  #219
express705's Avatar
Old Apr 21, 2008 | 02:45 PM
  #220
BeerViper's Avatar
Did you have this installed at the same time as the Procharger or was this when you were still NA? I'd be surprised if no oil was trapped with the Procharger unless that ARC catch can is just a bad design?
After a lot of research here and on my350z I ended up throwing some stainless steel cleaner pads inside the catch can to atomize the oil vapor and catch the oil. I ended up using a clear/braided vacuum hose from Home Depot where I can see the oil collecting on the hose barb already...
Old Apr 21, 2008 | 02:49 PM
  #221
g35man04's Avatar
CLUB MODERATOR
well from what I understand ATI is internall oiled...I dont run to my oil pan at all....the places on the plenum have been routed through the ARC catch can...on top of that you know the hose that connects to the backside by the throttle body that plugs into the Z tube or G-tube which ever you have....I had that welded shut on mine and tied it into the ARC oil catch can as well..
if that mkes any since...
Old Apr 21, 2008 | 03:00 PM
  #222
BeerViper's Avatar
It doesn't really have anything to do with how the ATI is oiled ... it's the additional boost pressure from FI that causes more blow-by than NA which is why I asked if you did it pre-boost or not. When you see oil inside the plenum, it is typically coming from the passenger side valve cover PCV valve outlet (where the catch can is installed between).
With the Vortech, the drivers side valve cover outlet (no PCV valve) is directed back into the air filter just before the blower impeller so there is a great deal of vacuum there as compared to NA. I'm not sure how the ATI reroutes the drivers side valve cover vent, if it just goes to atmosphere (messy) or if it's also redirected into the intake...
Old Apr 21, 2008 | 03:24 PM
  #223
G37Rider92649's Avatar
Me and G35man are the ex procharger riders
Old Apr 21, 2008 | 03:30 PM
  #224
g35man04's Avatar
CLUB MODERATOR
yes we aRE!
Old Apr 21, 2008 | 05:58 PM
  #225
Dan_K's Avatar
Is there a DIY for the drivers side?
