Well My FI Days Have Come To An End.....
Old Apr 7, 2008 | 03:49 PM
  #76
waijai's Avatar
i.love.gold
Originally Posted by Jeff92se
I'd also really suspect the oil level. Oil starvation would fubar a rod/crank bearing and seize it. Does you oil change receipt mention the # of quarts of oil used?
This brings up questions for me as well. If you just had work done by the dealership, and a few days later something goes. I would suspect something awry from the dealership.
Old Apr 7, 2008 | 03:54 PM
  #77
aRT13's Avatar
This makes me not want to go FI afterall...hmmm =/
Good luck man. I hope it all works out for you!
Old Apr 7, 2008 | 03:56 PM
  #78
g35man04's Avatar
CLUB MODERATOR
thats what I am going to check when I get home...I havent had any issues with my car at all until having the transmission worked on and the oil done this past week...what I am curious of is that i have been having trouble trying to start the car...or having it turn over..need to give alittle gas to turn over....
when this happend and I got underneath the car my starter is pretty much just snapped in half..I will get pics up tonight of it..I have them on my camera...
here is what it should look like...wait until later...
Old Apr 7, 2008 | 03:58 PM
  #79
waijai's Avatar
i.love.gold
When did your starting troubles begin?
Old Apr 7, 2008 | 04:02 PM
  #80
g35man04's Avatar
CLUB MODERATOR
its been like that for a while....almost since I have put on the procharger.
Old Apr 7, 2008 | 04:07 PM
  #81
rockd's Avatar
Originally Posted by g35man04
explain more what you mean by Fuel Setup..Oil level I am assuming it was full..I had just picked it up from the dealer after having the oil changed 5 days ago...I have a JWT Oil Pan spacer and told them that I needed an extra QT of oil...that was over the phone...did my service advisor tell the mechanic...I dont know....So if I only had 5 QTR's I would be starved for oil which would result in blowing the engine...
check your receipt from the dealer... it usually says how many qts of oil they put in. If they only put in 5, i would go and raise hell
Old Apr 7, 2008 | 04:09 PM
  #82
g35man04's Avatar
CLUB MODERATOR
okay will do I will check the reciept when I get home.
Old Apr 7, 2008 | 04:12 PM
  #83
FastDontLie's Avatar
...we dont need roads...
I have to give it some gas now, I think cause of the bigger injectors. Dont think that would have caused your problems...... Curious as to what the dealership may have done....
Old Apr 7, 2008 | 04:16 PM
  #84
waijai's Avatar
i.love.gold
I have starting problems only after I fill-er-up on gas. Takes 2-3 rounds of some continued cranking for 4-5 seconds. And I have 440s and walbro...no fuel return line.
  #85
g35man04's Avatar
CLUB MODERATOR
yeah I am the same way..I have called 4 times today and cannot get anyone to answer.
Old Apr 7, 2008 | 04:17 PM
  #86
g35man04's Avatar
CLUB MODERATOR
I had 550cc and the Walbro 255....if I didnt give it any gas it would not start...
Old Apr 7, 2008 | 04:20 PM
  #87
^^Yeah thats a different problem than just giving it a little gas every once an awhile that I have. Man, really sorry to hear....
Old Apr 7, 2008 | 04:21 PM
  #88
rockd's Avatar
Originally Posted by SKYLINE_GT
I have to give it some gas now, I think cause of the bigger injectors. Donnt thick that would have caused your problems...... Curious as to what the dealership may have done....
i agree... bigger injectors cause the car to "hesitate" a bit before it starts. almost like the car is in limp mode for a second or two, and then roars to life. it happens with most FI setups.
also, i doubt this blown engine can be traced to the procharger itself. let's not be so quick to judge... more than likely, it was the tune, which mysteriously cuts off at mid-5k RPM . also, u'r A/F ratio seems WAY too rich... mine stays between 11.5-12.0 until close to redline, when it leans out a bit.
Old Apr 7, 2008 | 04:30 PM
  #89
Mad A's Avatar
Yup, I'm at 11.5, and at redline I lean out to 12.0. Mid 10's sounds a bit rich to me as well. We'll know once the teardown is done I guess.
Old Apr 7, 2008 | 04:33 PM
  #90
superchargedg's Avatar
It would not matter if the dealer put in just 5 qts as that is what the engine takes.He has a spacer which gives the added protection of 1 more qt.
