HELP with TURBO EXHAUST!!
Old Apr 6, 2011 | 01:40 PM
Kenyatta43's Avatar
Hey guys! About to twin turbo my g35 coupe 6mt! I was wondering what the best exhaust out there for a TURBO g is? I was looking at the greddy Turbo TiC exhaust but really dont know if thats the best! I want a super deep and quiet exhaust unless you get on it! Anythings helps...thanks!!!!
Old Apr 6, 2011 | 01:58 PM
Silencer_0's Avatar
https://g35driver.com/forums/forced-...run-twins.html
You could also get the MotorDyne Shockwave V2 as a full 3", or the TDX like mine that starts at 2 1/2" then tapers to 3". But it's loud.
Old Apr 6, 2011 | 02:24 PM
Kenyatta43's Avatar
Yes sir! Whats the best HP gain dual exhaust? HKS seems cool but what others are there! I do like the dual burnt tips but like I said I want the best HP gain because Im running a APS twin turbo system! Thanks again
Old Apr 6, 2011 | 02:26 PM
Glex25's Avatar
Administrator
I'm running APS TT kit with built block and have used the Greddy Evo TT with no problems.
Recently i modified it and now using a custom 3" midpipe and now I'm getting too much flow.
Old Apr 6, 2011 | 02:33 PM
Kenyatta43's Avatar
Wow what kind of HP are you pushing? What are your thoughts on the turbo TiC from greddy?
Old Apr 6, 2011 | 02:55 PM
Glex25's Avatar
Administrator
I was pushing 550WTQ
Now that I have more flow the wastegate springs I was using are too strong (Forge Actuators with Red Springs which are 18psi) and I'm going with Forge Yellow springs which are suppose to be 11-12psi
Old Apr 6, 2011 | 03:34 PM
Kenyatta43's Avatar
So its a great system? I guess for 9 grand! lol Anything I need to be aware of? Im installing in a week!
Old Apr 6, 2011 | 03:39 PM
Glex25's Avatar
Administrator
Pull the motor it will save you alot of aggravation and time
Old Apr 6, 2011 | 03:46 PM
Kenyatta43's Avatar
Oh my shop is dropping the transmission and the engine! I bought the cd009 350z tranny, clutch,flywheel,waldrop intank fuel, utec fuel management, APS turbo and now the reason for this post...the exhaust! Am i doing alright?
Old Apr 6, 2011 | 03:59 PM
rcdash's Avatar
The biggest piping you can put on there paired with Dynomax VT mufflers will give you what you're looking for. It is quiet and drone free and pure performance at WOT. Too quiet for most people I suspect... I run a Motordyne TDX 3" with custom Dynomax VT axle back mufflers.
Old Apr 6, 2011 | 04:07 PM
herrschaft's Avatar
I'm using HKS and its a little loud for my taste at WOT, fine for normal driving though.
Old Apr 6, 2011 | 06:14 PM
MardiGrasMax's Avatar
I'm considering a Dynomax VT for the drone free thing, do you have any recordings of yours?
Old Apr 6, 2011 | 07:31 PM
Sylvan lake V35's Avatar
Which kit did you get? New or Used? Since you asked, APS started using cheap chinees turbos on one of the kits I am not sure if it was the tuner or Extreme i think it is the tuner kit? instead of the good ball bearing turbos they used to use, so people have had a hard time making over 550whp with them. It is about $1,200/turbo to get ball bearing centre sections swapped in. Also APS has non-existant customer service so hopefully you dont have any issues
4 years ago they were one of the best systems available and I really considered them but the lack of customer service and the fact they are located in Australia made me stay away and now with the cheap turbos they are among the last systems I would put on my car.
if you haven't bought it yet i would look into which kit has the cheap turbos and avoid that kit even if you have paid I would change out and get the kit with the good turbos.
For your original question, how much power are you looking for? dual 2.5" will flow more than enough for up to 500whp and i made well over 600whp with a Stillen 2.5" dual but if your goal is over 500whp i would get a dual 3" if 400whp is your goal any dual exhaust will work fine.
Old Apr 7, 2011 | 02:28 PM
rcdash's Avatar
Nothing yet - was going to wait to dyno it vs the v2 shockwave axle back units before I posted up. I've only had it a couple weeks and I have fallen in love with the car again. It's nice to hear the purr of the motor instead of the darned exhaust. $200 and probably a bit more for labor and you can just add it on to whatever exhaust you've got currently. Will be very quiet!
Old Apr 7, 2011 | 06:47 PM
nyqueenz's Avatar
Greddy EVOTT is what i have..very DEEP sound until my open dumps kick in
Video Share
Jan 31, 2017 04:00 PM
g.spot
May 9, 2016 10:54 PM
Red G Coupe
Tuner & Dyno
Jan 14, 2016 01:13 AM
