Everyone: Check Your Oil!
Damn Hexx. Have you been doing what I suggested? Check the oil about 20 times multiple times a day? Cant hurt haha. Good luck, keep us updated. Its killing me not having your car, so if they say they want/need to hold onto yours, dont let them!
6MT Coupe
Hey...that's cheating...
J/K
J/K
haha!! I have done that. And I have driven the car extra hard the past couple of days trying to burn a little bit extra oil.
In all seriousness, I don't see how they can say this is acceptable. I am right at or a little bit over that 1 quart per 1000 miles ratio. I will not be a happy customer if they say that it is acceptable and don't wanna give me a new engine. We will see though.
Just the other day, I got some loud clanking sound when I turned the car on similar to what u guys were describing. It seemed to come from the engine area as well. But I checked my oil, and it's fine, near the H mark. It hasn't done it since either. The car was left on an incline over the weekend and it made the sound on Tueday, which was the first time I turned her on since friday. Any suggestions what it could be as well? 6mt, 04.
When did you check your oil? Before or after you drove your car. If you checked it after it had been sitting all night or for a few hours, then you are probably okay and it is not the oil. But if you checked it right after you drove, it could be misleading because oil is all over the place and may not give you an accurate reading.
Drive the **** out of your car hexx. Take it to the redline and do hard down-shifts everytime. Check the oil like I said and just hope the oil level drops. When I checked my oil before I took it in, it was a little under the L mark but they told me I was about 2 quarts low, you never know! Best of luck
Hmmmmm . . . . okay. The guy at Glendale said they are just gonna check the dipstick, not drain the oil. I wonder if I should ask them to drain the oil and measure it that way? Either way, I have lost at least a quart, if not more.
No, they can't charge you for an oil consumption test. It is a test to see if your engine is burning oil and may need to be replaced which is covered under your warranty. 1500 miles? My dealer said 1000 which is why I am going in tomorrow.
