Owners of VQ Oil Consumption
On my 3.5 Altima I just live with it. It is quite annoying, but it way out of warranty. It's been about 1qt every 1500 miles. My OCI is 6-7K so that's almost a whole M1 jug... jeez. It seemed to consume more after using syn but it could be coincidence.
My G is on dino, and doesn't use much between changes. OCI is 3K.
I had my engine replaced and so far the best oil I have used with smooth sounds, no burning, no funky smells is castrol syn blend. Mobil 1 continues to burn much faster than any other. The dealership in Greensboro used Valvoline blend in it when it was brand new then I read paperwork and it said conventional only for like 15k to 20k. So who knows. For some reason it seems no one can get $hit straight anymore.
Be aware that different brands of oil will evporate at different rates. Check the test results published by Amsoil and see if the oil you're using is just evaporating. It might not be totally your engine's fault unless it's running hot.
warranty are useless
I do have an extended infiniti warranty. The car failed the oc test 15 mm in 1000 miles but they would not do any thing for me because it is for 05-07. such bs I hate that dealers are allowed to be so crookish. I filed a complaint to everyone kown to mankind but I dont think I will get anywhere.
P.O. Box 685003
Franklin TN 37068-5003
800.662.6200
8:00 a.m. - 5:00 p.m. Eastern / Central Time / Pacific Time
Monday through Friday
8:00 a.m. - 3:00 p.m. Central Time
Saturday
They put in my aftermarket JWT clutch and flywheel free of charge. You have to show them you are willing to get an attorney and they will kiss your feet.
Placed my Complaint today, including the tricks used by the dealers to obstruct any bad findings!!!!
Hope it will work.
In addition I added an oil Collector between the PCV and the intake.
Next week I will be adding one on the other half of the engine.
Hope with this to have evidence where the oil is going and how much !
Also as I described in my previous update I added 1/4 of a quart of 10W40 Castrol GTS High mileage and Lucas oil stabilizer in hope to reduce oil burning and Converter damage.
There were unexpected imediate results from the oil additives. The Acceleration and smoothness of the engine increased significantly !!!!
Hope it will work.
Oil Separator intermediate report.
Imediately after installing the first Oil Separator between the PCV Valve and intake, I noticed that the Vacuum, even during Idle is powerfull, it squized the two hoses to death !
I will change the hoses to thicker ones, but with this vacuum being so strong, its no wonder any oil is left in the engine !!! Remember that the passanger side valve cover is connected directly to the intake manifold without any PCV VALVE, so it must suck very hard !!!, any questions !!!
no, keep an eye on your oil and top it off, all you can do or replace it on your dime
Be careful with this issue and aftermarket warranties. I have came across a few that wont cover motor replacement due to oil consumption issues with client I had in the past.
My claim with consumption was also just declined. I learned Nissan and Infiniti dealers sell Quality guard aftermarket warranty on their used cars. They will not cover most the common problems by using their warranty that says They dont specify parts since they cover so much they will tell you whats not covered. Then make a vague few paragraphs whats not covered to use to their advantage to tie in most parts to not being covered. Just warning my fellow Infiniti drivers of this warranty.
g35 engine knocking?
Started up the G this past Saturday after sitting about a week. It made some real loud knocking-type noises at startup and later subsided down to this (video). I just want to make sure I'm not being paranoid and this is not the knocking sound of a engine with an OC issue. At 1st, I thought they could be the belts, but as I listened, I could hear the belts alone. This sound was something else. I've gotten the OC test done twice and of course, I pass with no issues found. Please check out the vid below and chime in please. Let me know your thoughts.
- DM
- DM
celwin
V36 Engine, Exhaust, Drivetrain & FI
11
Sep 28, 2015 03:52 AM
