fair ammount of vibration at around 40 mph
ii can really here it in the interior and through the tires and everything when im coasting it smooths out at higher speeds and higher rpms. this thing was perfectly fine and i havent hit anything.. any ideas? i have 20" iforged wheels, could it be a rear or front sway?
it just recently started, (past couple of days) it seems to come and go. i checked the air pressure and on one tire it was high so i thought this was the cure. it drove smooth for about 5 minutes then when i got to the open road it kicked in again. ill get off one exit and its pretty smooth, then go on another and it vibrates evey piece of plastic in the car. i did have one of the valve stems on my rims checked at a tire shop for a slow leak last week. is it possibly they f'ed up a weight or did smething wrong?
UPDATE! im going to update and i wish everybody would do this in theyre threads. i took my car to an allignment place here in town and they confirmed one of the brake calipers was locking up. this explains why the vib comes and goes. anyway they suggested i replace calipers on both sides for even braking which i did. $550 the problem is solved.
A sticking caliper won't specifiaclly cause wobble. Rather it will cause the car to veer to one side, as though your tracking is out. You'd also smell it, as the pads would be burning. Have you definitely got new calipers on there? You sure they didn't just balance you wheels, and flog you some calipers at the same time?
That's why i said it doesn't sound right. A sticking caliper would cause a car to veer to the side and would be constant. It wouldn't pulsate and disappear at speed like that. It would smell like burning brake as well.
I would be wondering if they just balanced a tire for you and then sold you $550 of stuff you didn't need to make a few bucks
Are your calipers new? Can you see that they changed them?
The caliper was replaced and It was bad. I remember after only a 5 minute drive pulling over and rinsing the car off and that caliper was sizzling and steam came out. The others were fine. Also the brake wasnt fully pressed or Anything. Just hit It enough to cause the car to vibrate he said the rotors are a bit warped and that cause the vibe. I'm doing my own brake pads and rotors though. Hopefully project mu and new rotors of some kind. The project mu are on backorder everywhere.
THMotorsports
Suspension-Vendor
257
12-18-2018 05:43 PM
