G35 & G37, Coupes & Sedans
Horrible Gas Mileage
Old Feb 18, 2010 | 12:46 PM
  #91
tiguy99's Avatar
Originally Posted by SxSkyLinexS
^ that would be a miracle
18 to 40!
horsepower from 300 to 100
Well they are making a G25 soon. Would make a great contender for a hybrid.
Old Feb 18, 2010 | 01:29 PM
  #92
threeputzzz's Avatar
I wonder where the G25 turbo will be priced relative to the G37?
Old Feb 18, 2010 | 02:23 PM
  #93
blueG1's Avatar
by some kind of miracle i manage to get 390 miles to the tank. i only did it once and never been able to get that again. no i get between 320 to 340. A tune up will help especially if you get iridium plugs. I got those now and besides the noticeable extra power it improved gas mileage. did it on my coupe and on a 04 sedan, same results.
Old Feb 28, 2010 | 02:40 PM
  #94
mike_gt2's Avatar
new platimum tipped spark plugs and air filter, 93 gasoline from chevron or mobile, O2 sensors and all other sensors work fine according to the diagnostic, still driving gently, bg air intake system cleaner process was done, and car is still running rich. getting only 11 mpg or about 190miles per tank after 18 gal fillup. as much as i love it, i wish i never got this coupe sometimes. =/
Old Feb 28, 2010 | 02:55 PM
  #95
mike_gt2's Avatar
btw, got a P0172 code and p0442...also wanted to share this with yall(pics are after fillup and driven about 40 and 90 miles...check out the gas gauge)
<br>Name:  IMAG0188.jpg
Old Mar 9, 2010 | 11:41 PM
  #96
mike_gt2's Avatar
any suggestions?? =/
Old Mar 10, 2010 | 08:54 AM
  #97
SedanManBen's Avatar
http://www.obd-codes.com/p0442
http://www.obd-codes.com/p0172
Old Mar 10, 2010 | 09:01 AM
  #98
just as a follow up and to give you doubtful owners more hope... I have an 03.5 sedan with 151k and I get roughly 320-340 miles per tank.. ~22-23 mpg
I only started observing this after a meticulous tune up and the plenum spacer/exhaust mods... before that I got ~17 mpg
Old Mar 10, 2010 | 09:31 AM
  #99
xxkylexx's Avatar
I haven't got less than 20 mpg yet in my 06 6MT coupe. And I drive kinda hard sometimes. semi-city driving mostly.
Old Mar 10, 2010 | 12:03 PM
  #100
Abdizzle's Avatar
I found the upper half of the gas gauge to be extremely inaccurate/non-linear. After about half way it's consistent.
Also based on your picture you are achieving like 10MPG which is highly unlikely. My guess is your sending unit is out of whack or something related to that. Best way to test is run it as empty as possible and proceed to fill up and see how many gallons it takes.
Old Mar 10, 2010 | 12:12 PM
  #101
blazeplacid's Avatar
extremely inaccurate??
i dont know about extreme
its pretty close for me
The gas tank is not a perfect square or rectangle and the fluid takes whatever shape the tank is, which causes the gauge to read weird in that case.
i usually get 400 miles to the tank but its all high way to work.
from full to 3/4 i get 100 miles
3/4 to 1/2 200 miles
1/2 to 1/4 300 miles
Old Mar 10, 2010 | 12:13 PM
  #102
mike_gt2's Avatar
yea i dont go by the needle at all. it was just to give you all an idea. it is pretty accurate though. i usually fill her up with about 18 gals and my trip A registers about 185-195 miles which is just sad. then i reset trip A after fillup and do it all over again and get the same results time after time. i pretty much just use it to go to work now. i wish i could get 17mpg. =/
Old Mar 11, 2010 | 11:49 PM
  #103
quorum's Avatar
I was just going to post a new thread that I get 16.7MPG driving conservative short distance trips. Now I find this thread and I realize my fuel economy is normal. I drive an 06 G35x.
Old Mar 12, 2010 | 09:06 PM
  #104
mike_gt2's Avatar
u should be grateful =)
filled her up today and got 10.6mpg...<sigh>
182 miles/17.2 gals
My stepdad's E350 V10 with a **** load of cargo gets 9mpg...lol
what a love/hate relationship i have with this car and no mechanic can figure it out
Old Mar 12, 2010 | 10:48 PM
  #105
HwyDrftr's Avatar
182 miles/17.2 gals
That thing must be running way rich, that's not a good thing...can wear rings and more if enough fuel gets in the oil. Have you pulled the plugs? do they look like this?
