G35 & G37, Coupes & Sedans
Old Feb 8, 2017 | 07:55 AM
  #6991
LoSt180's Avatar
Replaced my clutch over the weekend. Went with a CZP flywheel and Exedy clutch kit. Still have master and slave cylinders to replace, ran out of time.
Also installed a Z1 Motorsports trans mount. Don't think I like it. Shifts feel great and no slop off the line, but even though it's urethane, it transfers a lot of noise into cabin. I thought I installed something wrong or had a blockage in my exhaust. Definitely makes the car sound and feel more like a race car vs GT cruiser. I'll give it another week to see if it grows on me.
One more burnout pic:
Old Feb 8, 2017 | 11:06 AM
  #6992
Urbanengineer's Avatar
One of the negative side effects of a solid performance car with poly/hard bushings/mounts... it's a lil creaky/noisy!
Old Feb 9, 2017 | 02:21 AM
  #6993
Mr. Brooks's Avatar
Burn out looks great, how long was the clutch install.
Old Feb 9, 2017 | 09:32 AM
  #6994
LoSt180's Avatar
It took me and a friend 6 hours. I planned ahead and got new gaskets and hardware for my exhaust, as expected the bolts snapped.
I wish I had investigated a burning oil smell before hand though, turns out a cam angle sensor is leaking and dripping oil onto the manifold. Would have been so easy to replace with the trans off.
Old Feb 9, 2017 | 02:10 PM
  #6995
saywat?'s Avatar
u can buy o rings from orielys for a few bucks.
Old Feb 13, 2017 | 01:07 AM
  #6996
ferrari71298's Avatar
Smile Today I made "The Switch"
Hello everyone!
I lurk around the forum mostly reading and devising plans but today I would like to share with you my take on the classic "Make your AWD g35x a rear wheel drive G35 (with an extra couple pounds and an open diff)". I used the "make your AWD g35x rwd no joke" thread as guide and my own adaptations to do this.
I installed the switch in my center console, took a little bit of work with a dremel to get the switch itself to fit with all of the plastic ribs hiding underneath. Down position with the safety cover on it is all wheel drive, and up is rear wheel drive. I admit it would look better with a black interior and the "Rice" factor is maybe too high for many of your tastes.
I put a sheet of felt around it because it looked kinda naked in contrast to the tan interior.
Link to switch for those curious:
Amazon Amazon
and a link to the thread that started it all: https://g35driver.com/forums/v36-eng...d-no-joke.html
I think with crimps and wiring my total was $15; and with about an hour and a half invested in the project to completely change how the car drives is fantastic.
Old Feb 13, 2017 | 01:15 AM
  #6997
djfarhan's Avatar
officially 10 yrs old and travelled over 170k mi in 4 countries between 2 continents. Ride or die my G.
Old Feb 13, 2017 | 03:45 AM
  #6998
Blue Dream's Avatar
I drove ttrank's car solo
Originally Posted by ferrari71298
Hello everyone!
Link to switch for those curious: https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1
I read this post in a notification and came here ready to bash away but call me crazy, I like the look! Plus you get to choose on the fly how you want the car to behave. Great job.....
Plus you're a fan of the greatest band to ever live (I've seen them 14 times live) so there's that.
Old Feb 13, 2017 | 09:40 AM
  #6999
You probably should have installed this as a hidden switch, but pretty cool you found a way to get what you want.
I know lots of people put a switch to the "Yaw sensor" to activate no traction control hooligan mode. This must be similar!
Old Feb 13, 2017 | 10:47 AM
  #7000
Thank you much. I saw them when they were in town for R40 but I'm too young to be able to say I've seen them elsewhere. 2112 sounds great with the Bose audio package! I had an extra vinyl sticker laying around so I put it on there.
Half of the reason I put it there was because with a little mod like this. it puts a smile on my face when I flip it up, shift it forward and then go into the "danger zone". Really puts you in the mood for a fun drive. If it wasn't as clean of an install it would look terrible imo but I'm glad it worked out and I don't have to buy a new $50 trim piece. Also gets the attention of perspective passengers and then launches into a discussion about what all I've done to the car, which is always fun to discuss.
Old Feb 13, 2017 | 10:53 AM
  #7001
It is somewhat similar from what I understand. It was originally going to be hidden but wheres the challenge in that?
VDC still works with AWD disabled and pretty well I might add. Dash only lights the AWD light and nothing else. I haven't really done anything too "hooligan" yet because I like my tires. But next heavy rain/snow I will report back on its abilities. Does the VDC button not turn it off enough for a little fun? if not then whats the point of having an off button?
Old Feb 13, 2017 | 12:23 PM
  #7002
It sort of turns it off, search for more info on that subject .
Old Feb 13, 2017 | 05:56 PM
  #7003
Albanian122's Avatar
finally ordered final items needed for akebono swap on my g35 should be installed in the coming weeks
went with Z1 two piece rotors SS lines OEM pads ATE dot 4 fluid and upgraded master cylinder brace from Z1
Old Feb 14, 2017 | 07:34 PM
  #7004
Conissah's Avatar
Drove it after I fixed some rubbing issues. Should've turned my demon eyes on...
Old Feb 14, 2017 | 09:53 PM
  #7005
EPiK's Avatar
I guess I need to read up on VDC... when I turn off mine I have no problem steering the car thru the turns with the throttle. When the VDC is on it cuts power at the first slip of the rear wheels. So I guess I should figure out what else I'm losing (?) with it off. I actually prefer the car without all the doodads driving for me. That's why I have a rwd 6mt
