G35 & G37, Coupes & Sedans
Old Nov 25, 2019 | 07:59 PM
  #10066
joeb1983's Avatar
G35
Front bumper is fitted. Hopefully it’s all done soon.
Old Nov 25, 2019 | 11:21 PM
  #10067
Mr. Brooks's Avatar
is that transmission cooler and a oil cooler between the intercooler.
Old Nov 25, 2019 | 11:32 PM
  #10068
Yinster's Avatar
5 Year Member
Dang I want some. I missed out on the G35 Tamaya kit and that makes me sad.
tomica's g35 sedan could get pricey, but at least its easier to find than the coupe version
1/43 model of g35 should be easy to find still
Old Nov 26, 2019 | 10:49 AM
  #10069
Urbanengineer's Avatar
Ugh I want this hood so bad.
Old Nov 26, 2019 | 10:50 AM
  #10070
:why not both meme:
Noted...!
Old Nov 26, 2019 | 01:20 PM
  #10071
joeb1983's Avatar
G35
The large cooler is oil and the smaller one is power steering. (Same rows as CZP's upgraded Setrab power steering cooler upgrade kit.)
Old Nov 26, 2019 | 02:49 PM
  #10072
joeb1983's Avatar
G35
My buddies all give me crap for painting the hood given its carbon fiber, so I went ahead and did the same with the trunk. Lol!
They are both SEIBON, but my painter said the trunk, by far, had a much more smoother finish.
Anyway, I got the hood simply to let heat out. In my opinion it was the least aggressive vented hood on the market. Call me crazy, but I prefer the stock hood.
It does let heat out that's for sure, especially with the fans on. Again, I am not a fan of the gaps on either side, but the hood does allow you to hear the blower more.
Old Nov 29, 2019 | 02:35 PM
  #10073
whutch1's Avatar
This week:
INstalled a new rack and pinion (pro forged links) along with the necessary alignment
tightened up the suspension a bit (moved the Hotchkis front sway bar up another notch for a stiffer response in turns)
On the struts: tightened up the pre load all the way around (have megan track series full coil over all 4 wheels)
replaced the back driver side caliper and new ceramic pads
Positioned all the spark plugs so center opening is centered
re sealed a valve cover (had some leaking oil from previous repair)
detailed the engine bay
Still need to put on driver side rear spindle as the parking brake bolt head was sheared off trying to fix another issue.
Previous work: Valve covers replaced; ADD W1 oil catch can
Old Nov 29, 2019 | 05:14 PM
  #10074
eazdaskeez's Avatar
Changed plugs and cleaned throttle bodies. Had an high idle so used the app to reset it. I'm almost sure these plugs are original because of how effing tight these plugs were and the condition.
Yes one was caked in oil. Wasn't aware the hr model suffered from leaky valve covers as well.
Old Nov 29, 2019 | 05:27 PM
  #10075
whutch1's Avatar
Looking like Ike an O ring failing to hold fluid in.... thing for another day
I do say there’s was a failure hereabouts
Problem child trying to remove with rust intact
Old Dec 1, 2019 | 11:24 AM
  #10076
Morning, I had the same issues. I had to replace it with a reman one.
Old Dec 3, 2019 | 05:11 PM
  #10077
joeb1983's Avatar
G35
Back from the body shop.
Old Dec 3, 2019 | 05:36 PM
  #10078
Fitment is really good! Nice!
Old Dec 3, 2019 | 07:27 PM
  #10079
Mr. Brooks's Avatar
Looks good, where did you get the trunk from
Old Dec 3, 2019 | 11:59 PM
  #10080
joeb1983's Avatar
G35
Appreciate it! A few adjustments needed here and there, but nothing of concern.
I purchased the trunk from Mobb Motorsports.
