G35 & G37, Coupes & Sedans
G35 wont turn on after a drive
Old May 12, 2016 | 07:00 PM
Zokey36's Avatar
My g35 is starting to act stupid, like three weeks ago i was driving it around for like 20 minutes i got back home turned it off went in for like ten minutes came out tried to start it and nothing no crank no sound at all tried to jump it nothing the camshaft sensors are new , new starter battery sparkplugs what could it be last it only happens after i drive it for a more than 5 minutes i have to let it sit ovenight sometimes even three days i cleaned all the terminals grounds everything could it be another sensor please help guys 2005 g35 coupe 83,000 miles
Old May 12, 2016 | 09:45 PM
hurleyguys's Avatar
check all your fuses. any check engine lights? when you cleaned your grounds did you sand the metal that it contacts? sometimes there is debris under the grounds that doesnt allow it to make good cantact. have you done any recent work on your car before the symptoms started to happen?
Old May 15, 2016 | 08:53 AM
telcoman's Avatar
Veteran: Army
Have you tested your battery?
Telcoman
Old May 16, 2016 | 12:58 AM
Zokey36's Avatar
Telcoman
I tested my battery alternator and starter its all good could it be a sensor heating up
Old May 16, 2016 | 03:00 PM
telcoman's Avatar
Veteran: Army
What and how did you test?
Did you test the specific gravity of each cell in the battery?
Page SC-06
"If, after charging, the specific gravity of any two cells varies more than 0.050, the battery should be
replaced."
Have you tried following the steps in the FSM?
http://www.nicoclub.com/FSM/G35/Coupe/2005/sc.pdf
See pages SC-10, 11
Telcoman
Old May 20, 2016 | 10:09 PM
Zokey36's Avatar
Page SC-06
replaced."
See pages SC-10, 11
Telcoman
Thanks man for this ima check everything all my fuses the battery was bought a month ago dont think thats the problem when the car decides not to turn on it doesnt make a sound a click or anything just the lights turn on, radio all the normal stuff even if i try to jump it nothing its very frustrating one day my car stayed without gas and i kept trying to turn it on and it was just cranking and cranking i tried about five times then it stopped it would crank anymore it would just do a click so figured maybe i killed the starter , so i got the car towed home jacked it up took the starter took it to get tested and it failed bought a new starter installed it the car still didnt turn on till the next day i tried jumping it and boom it turned i drove it good for about two days without any problems then it started doing the thing were it wouldnt crank or turn on after i drove it till the next day and now it litterally doesnt turn on i tried every other day and nothing till one day after four days of just sitting there without being touched i went to try and boom it started without a problem i drove it for 15 minutes and the car ran like a champ i got back home parked it in the knowing that it wasnt gonna turn on its been a week and nothing the cars just sitting
Old May 24, 2016 | 07:20 PM
Zokey36's Avatar
Page SC-06
replaced."
See pages SC-10, 11
Telcoman
Could it be the crank sensor i mean the car does not crank at all
Old May 25, 2016 | 12:11 AM
hurleyguys's Avatar
did you buy an OEM starter? could be just a bad starter.
Old May 25, 2016 | 10:58 PM
Zokey36's Avatar
They were discontinued and i got one from autozone
Old May 28, 2016 | 08:04 AM
telcoman's Avatar
Veteran: Army
Why would you replace a OEM starter without testing it first by applying 12v to it while out of the vehicle?
If it was the starter why would you not have a rebuilding shop rebuild it instead of buying some piece of crap from Autozone?
When you hear just a click and the starter does not operate that is a clear indication of a defective battery no matter how new it may be.
When hearing just a click had you measured the voltage across the battery with a voltmeter you would observe the battery voltage drop from around 12v to approximately around 6-7v which is why the starter will not crank.
As I previously suggested to you TEST YOUR BATTERY!
Don't be too embarrassed to let us know the final root cause of your problem.
You'll be helping others not to make the same troubleshooting mistakes that you did.
Good luck
Telcoman
Telcoman
Old May 30, 2016 | 11:06 PM
Zokey36's Avatar
Good luck
Telcoman
Telcoman
Could the alternator be dead ima take out the battery starter and alternator tomorrow take them to get tested
Heero
Jun 7, 2018 01:07 AM
Shawn1984
36
Aug 6, 2016 08:38 AM
Jason Koch
Mar 10, 2016 02:22 AM
Jgonzalez
Mar 3, 2016 12:20 AM
bongoz
Feb 23, 2016 10:42 PM
