Drove through a big puddle of water?? Should I worry about it?
May 28, 2019 | 01:52 PM
Update:Just took it out for a spin and the transmission did not make noise during startup like last night.The car drove normally but I noticed my brakes were horribly noisy. Here is the video of my engine after driving for a few minute.Im thinking it might be the new belts that I just placed in yesterday that is making that ticking
EDIT:Here is a vid from when I first got the car
seems like it’s been making the noise since this was around January
Reply 0
May 28, 2019 | 02:00 PM
Brake rotors rust VERY easily, once you drive around a little bit the noise should go away but be aware that soaking the calipers like that can cause problems if the slide pins haven't been greased in a long time. The caliper is designed to center itself on the rotor and rusty slide pins causes the caliper to stick.
Reply 0
May 29, 2019 | 02:47 PM
Quote: Brake rotors rust VERY easily, once you drive around a little bit the noise should go away...
Yeap, mine will rust over if it sits for over a day or so, especially if it's humid or rains. Apply the brakes 2-3 times and they're "clean".
Reply 0
