G35 & G37, Coupes & Sedans
Installing pop up navigation on 2006 G35
Old Nov 24, 2019 | 10:46 PM
brutalg35's Avatar
2006 Infiniti G35 Coupe 6MT
Hi guys,
I recently bought a 06 G35 coupe which doesn’t come with navigation. I really like the pop up navigation and want to install it on my car. How can I do that?
just putting this here because I couldn’t find a satisfiable/explanation thread anywhere.. thankyou
Old Nov 25, 2019 | 09:15 AM
Urbanengineer's Avatar
The navigation available from the OEM is out of date. Would highly recommend a $13 phone mount and google / Waze / Apple maps.
Old Nov 25, 2019 | 09:29 AM
brutalg35's Avatar
Actually, I want to install factory navigation for it’s look; not for the maps. btwn, I saw a video on youtube in which this guy modifies his navigation screen to mirror it with iPhone. It worked perfectly.
Here is the link for the video and I want to set it up just like this
https://youtu.be/59Kc9CUxMqU
But there’re no videos showing how to setup navigation in car, so I have no idea what all components need to be bought, specs etc..
Old Nov 25, 2019 | 11:03 AM
TokkioDrift's Avatar
04 6mt Coupe - motordyne 5/16 ART pipes TDX2; KWv2; Hotchkiss; custom seats.
If your car didn't come factory equipped with gps, it's a nightmare octopus of a harnesses to get a gps that is so ancient that my office park (built a decade ago) is not on the latest map revision and an entire spur of a highway in the metro jax area is missing (even though it existed during the last revision). Here is a sticky from the AV subforum: https://g35driver.com/forums/audio-v...em-my-car.html *Tho, if you're already removing your dash for some other project (crack repair or some AC/Heat issue) it would be a good time to do this upgrade if you were still inclined.
1- The cheapest/easiest route is using a phone with a mount as Urban said. If you look over in the AV section, there are some threads of people who did custom tesla-like ipad/tablet mount in the center console.
2 - Another route to have the 'cool' popup is to buy just the screen module, which will wire in to a non-nav optioned car. Find a tablet or upgraded touchscreen that will fit or fit for a raspberri pi or something if you're techy (https://g35driver.com/forums/audio-v...ment-info.html for inspiration). Con is that you lose the cubby (which is useful in a car with limited storage options) and you have the now-useless (unless you're super techy) nav buttons sitting front and center.
3 - Get a DDIN with something with Carplay or AndroidAuto and/or a full gps built in. Con is obviously losing the design factor of the popup, and the cost of getting everything required...but its a great leap from OEM once you get everything sorted. Even though I have a full stealth radar installed and generally drive the same routes, I see a value in the traffic/speedtrap alerts that come from waze and gmaps.
Also, Just want to share this because its pretty rad, even if it's not my cuppatea. Check out the work that went into this full custom rework on an ls build: https://www.diymobileaudio.com/forum...r-upgrade.html
Old Nov 26, 2019 | 08:26 AM
kelman81's Avatar
G35 Sedan Leather Base, Z1 Plenum Spacer, Z Tube (Currently sold to a friend)
Old OEM navigation is severely outdated and annoyingly bad. I suggest you do what I did and install a modern Garmin on the underside of the cubby lid (where the factory pop up unit would go).
https://g35driver.com/forums/audio-v...cubby-lid.html
The live traffic is excellent when connected to data from my phone, as good or better than Waze. I also enjoy the backup camera, it can read text messages to me, weather forecasts... it is featured packed. It is slightly smaller than the exact width of the cubby so I can take it down and stow it in the cubby for security when I want.
Old Nov 26, 2019 | 09:02 AM
telcoman's Avatar
Veteran: Army
Originally Posted by brutalg35
Hi guys,
Buy a used Tesla
They have a large screen and great navigation
Did I mention they do zero to sixty much faster than any Infiniti
Old Nov 26, 2019 | 09:20 AM
kelman81's Avatar
Originally Posted by telcoman
Buy a used Tesla
I think you cracked the code. Apparently more money is the answer!
Old Nov 26, 2019 | 01:52 PM
909's Avatar
909
Your mom's boyfriend
Harlemkid82
Jun 2, 2019 05:32 PM
Rodogg
Apr 25, 2010 01:25 AM
KPierson
V36 Audio, Video & Electronics
322
Jan 14, 2009 12:52 PM
god_of_cpu
Car PC
27
Feb 9, 2006 05:42 PM
henry_mark0
Sep 13, 2005 08:39 PM
