mobil 1 oil filter
Old Oct 18, 2003 | 02:51 PM
jaxxx's Avatar
mobil 1 oil filter
i was going to buy one yesterday...looked at one part# m1-110 and noticed that it was much bibber than the Fra, double guard that I bought for the G35c...
So i want to know whats the correct size? the FRAM DG was alot smaller than the mobil1
Old Oct 18, 2003 | 03:17 PM
bkchang79's Avatar
Re: mobil 1 oil filter
as long as it fits. The length doesn't matter as long as you're increasing the size not decreasing.
2003 G35 Coupe 6mt Diamond Graphite
1992 Jeep Cherokee Blk 5.5 RE lift /w 33s
AIM= bkchang79
Old Oct 18, 2003 | 07:16 PM
Channon's Avatar
I called Mobil 1 and asked them what the part number was for an 2003 G35 Coupe with the 3.5L engine. The service guy typed in my info and got back M1-108. I bought both the M1-108 and the M1-110. When I took the stock filter off (first oil change), the M1-108 is alot smaller in length then the stock one, so I used the M1-110.
The previous post is right though, as long as it fits, the increased length will not matter.
Old Oct 18, 2003 | 09:33 PM
jaxxx's Avatar
when u say "fit" u mean by the diameter or the oil filter right?
thanks for the answer
Old Oct 19, 2003 | 01:27 AM
bkchang79's Avatar
yes same diameter
AIM= bkchang79
Old Oct 19, 2003 | 01:53 AM
RaySur350GT's Avatar
I use the Mobile 110 b/c it's bigger which means more oil flow and capacity on the filter.
- Don't argue with idiots. They will bring you down to their level and beat you with experience.=P-
Old Oct 19, 2003 | 06:04 AM
6MT_Coupe's Avatar
Hey,
Where are you guys buying these Mobile 1 oil filters? I have gone to both Pep Boyz and Kragen and neither of these stores have them (here in Cali).... Also, are these filters specially made to handle synthetic oil, or doesn't it matter?
Currently, I have the Fram oil filter too. Please advise.
Thanks, Jaime
Here's to alcohol : The cause of ... and answer to all of life's problems.
- Homer Simpson
Old Oct 19, 2003 | 07:49 PM
don1's Avatar
Working with people in the filter industry, many consider Fram to be about the worst, or as someone likes to say, "you'd be better off putting toilet paper in a coffee can to filter your oil" ...
Of course everybody has opionions on brands, but until you cut open the filter with a saw to see material quality and design, you are just relying on these opinions.
Old Oct 19, 2003 | 07:54 PM
AirSplat's Avatar
Hey guys. do you guys know which car the 110 is for. Becuase the 110 is mobil specific and not brand specific. Therefore, if I knew which car the 110 was for, then i could buy a larger oil filter which would also fit our G35's but be by a different manufacturer. Thanks guys. I would hate to have my oil changed and end up with a smaller oil filter than I originally had.
AirSplat.com for AirSoft Guns!
Old Oct 19, 2003 | 08:38 PM
khsonic03's Avatar
You can get the Mobil 1's at Autozone. Back in the day, Walmart used to sell them. I haven't seen them there recently. FRAM??????!!!!!! Oh no. The worst filters ever! Purolator makes a Pure One filter that is the same size as the Mobil 1 M1-110. That is the filter I used for my first oil change. The Purolator part number is PL14620.
This is from another post(I didn't do the research on these):
Larger Filter:
AC Delco: PF2057
Fram: PH7317
Purolator: L14620
Mobil1: M1-110
Wix: 51356
'03.5 Brilliant Silver Sedan
Premium, Aero Kit/Package, Sport, Winter
Stillen Air Box, Z pipe, Clear Corners, Alum Pedals
Polk Tweeters
Old Oct 20, 2003 | 12:30 PM
ryoken's Avatar
That's from this thread:
My first oil change!
It also includes the standard filter numbers.
I think one of the late 90's Maxima's used the larger filter as the OEM filter.
Old Oct 20, 2003 | 10:27 PM
AirSplat's Avatar
That's awesome! Thanks guys! ;-)
Old Oct 21, 2003 | 02:58 AM
LetsGoo's Avatar
lol u guys will probly think im nuts but what is an oil filter good for and will it improve performance ?
Old Oct 21, 2003 | 01:11 PM
ryoken's Avatar
It won't improve performance, but lack of one can seriously impact your 1/4 mile times... it's hard to keep accelerating after the engine seizes up and throws some of it's parts into the fender well. [img]/w3timages/icons/smile.gif[/img]
Just on the off chance that you're not joking, here you go: The oil filter filters dirt and debris out of the oil, to prevent wear and tear on your engine internals. There are good filters and bad filters. Bad filters clog up early and go into bypass mode (where they still let the oil flow through, but without filtering it) and they don't clean out as many smaller debris particles as the better filters. It's not a performance improvement, it's an engine maintainence thing -- and a well-maintained engine won't degrade in performance after several years of operation.
g.spot
May 9, 2016 10:54 PM
BradMD_96
Oct 6, 2015 09:31 AM
vamarris
Sep 26, 2015 12:56 PM
sullivan72
Sep 22, 2015 11:39 PM
