oil consumption test.!! WTF.!!!
Old Nov 9, 2006 | 08:41 PM
2006_G_coupe's Avatar
I bought my coupe 6mt in may...I went to the dealer for this harsh ticking noise that came from the driver side of the car.As i bend down to hear it the noice was comming from the right side of the engine(with the hood open to the right of the motor).So..i took it in and they told me that the fuel dampener had to be replaced.I said ok fair enough.Then i get my oil changed at the local goodyear at around 1075 miles.Everything was great.I watched the guy put in 5qts of mobil-1 5w-30 that i carried with me for the guy to put in.Plus a k&n oil filter.Now,about a week ago i hear the same harsh noise i heard before.So yesterday i brought the car back to the dealer to see what was up.The guy calls me back 3 hours later and tells me that my car didnt have the same problem.!! I said ok well then tell me..He said that my car only had two qrts of oil when he looked at it.!! I told him that i dont really drive that much and the car had an oil change not even 3000 miles ago.(Going on 7 months i have 3900 miles on my car) Long story short...They told me to run the car another 1000 miles with the new oil that they put in and to come back because they are doing a oil consumption test on my car.!!! He told me that if the oil burns again like it did than i will get a new motor.!! I need some input on to whats going on with the car.!! Any advise would be very helpfull.!!! Thanks in advance.!!!
Old Nov 9, 2006 | 08:47 PM
dream_G35's Avatar
hehe go for the new motor
Old Nov 9, 2006 | 08:48 PM
You better believe it.!! ^^
Old Nov 9, 2006 | 08:52 PM
Gammawolf's Avatar
^^^I assume you've already seen this thread (everybody: check your oil) https://g35driver.com/forums/g-spot/110973-everyone-check-your-oil.html
Looks like you'll need a new engine. Sorry bro.
Old Nov 9, 2006 | 08:56 PM
Originally Posted by Gammawolf
^^^I assume you've already seen this thread (everybody: check your oil) https://g35driver.com/forums/showthread.php?t=110973
Yea i know. but as new as the car is? Just doesnt make sense to me.!! I drive like a grandma but open up every once in a while.!! Oh well
Old Nov 9, 2006 | 10:01 PM
Diamond G35's Avatar
This seems to be a problem with many of the newer VQ35 engines.
Is this a year specific thing, or does the problem exist across all years?
Old Nov 9, 2006 | 10:09 PM
extreme4377's Avatar
Lexus IS350
My new engine ships out on Monday the 13. My car had less than 5K miles when this problem started. I finally took it in at 10,150 miles to have the oil consumption test done. At 11,600 miles, Infiniti is replacing the engine. Best of luck.
Old Nov 9, 2006 | 10:20 PM
gary c's Avatar
This doesn't look good.................!!
Ever since I started reading posts about oil
consumption I check my oil once a week.
From what I can tell the problem exists with
the newer '05/'06 engines. Oil must be slipping
past the rings but that should be noticeable. WFK
Old Nov 9, 2006 | 10:30 PM
DannoG35's Avatar
Oh damn........I need to go check my oil.
Old Nov 9, 2006 | 10:35 PM
04Rg35's Avatar
So this does not happen with pre 05 models? I have an 04.
Old Nov 9, 2006 | 10:42 PM
g35newbps2's Avatar
you guys make me scared with posts like this... I have an 06 - no noise yet but here I go to check the oil!
Old Nov 9, 2006 | 10:45 PM
gary c's Avatar
New Heart..............
Did anyone tell you what was causing the oil consumption? Hope your new engine will do the
job for ya.......enjoy the breakin process all over again! LOL
Old Nov 9, 2006 | 11:11 PM
denizen's Avatar
can anyone confirm that this problem is just for a small percentage of motors or is it ALL??
Old Nov 9, 2006 | 11:22 PM
Skyline_G35's Avatar
English dude, English
Is it just me or does it seem that the 05 and 06 seem to have more oil consumption issues. I've got 60k+ (03.5 6mt) and have no issues whatsoever. I run it hard too. It really disappoints me that a recall hasn't been done yet for all 05 and up motors.
Old Nov 9, 2006 | 11:43 PM
boknows's Avatar
My theory is that the piston rings weren't set correctly when you drive the car like a grandma. Read this: http://www.mototuneusa.com/break_in_secrets.htm
I'm not a mechanic so this is just a theory based on what I've been reading about oil consumption issues on this forum and how their drivers drive. I'm still monitoring my car (520 miles) and crossing my fingers that it doesn't have the same problem.
