Reset ECU?
Old Nov 12, 2003 | 09:27 PM
gregG35C's Avatar
Reset ECU?
A lot of you folks have reset your ecu after the break-in period on your coupe. How do you do this? Will dealer reset for me? What did it cost? Does it really enhance performance with the 5A? I am at about 1900 miles. Thanks
Old Nov 12, 2003 | 09:41 PM
uheenada's Avatar
Re: Reset ECU?
no need to go to dealer... easiest way is to disconnect the battery for at least 5hours(i did 5hours and it did resetted.. any1 done less and worked?)... it's easy as that... and AT tranny is the one will get most benefit from reset ECU due to stupid adaptive transmission... from my experience, after reset, i felt like i've been driven with only 80% of power b4... get ready to say hello to your lost 20% power...
Old Nov 13, 2003 | 10:59 AM
AntRock's Avatar
Re: Reset ECU?
if you do a search on the dyi section there is an easier way without disconecting the battery and it only takes minutes!
it involves foot rythem and thats it!
Old Nov 13, 2003 | 11:33 AM
Msedanman's Avatar
O.F. Administrator
Re: Reset ECU?
Here's a link to the ECU resets in our DIY forum that Antrock mentioned: ECU Resets.
I should point out that the Nissan service manual recommends 24 hrs battery disconnect. I personally do a 12 hr disconnect. Some of our members do a shorter one and say it works too.
GSM
<font color=red>GSM</font color=red> <font color=black>Silverstone Coupe</font color=black>
Old Nov 13, 2003 | 11:37 AM
Bigsmasher's Avatar
Re: Reset ECU?
i have 6100 miles on my 5AT, is it too late for me to reset my ECU??? I never knew about this
2003.5 Black w/ Willow G35 5AT
Premium / Sport / 5% Tint / Injen intake / 20" rims
Old Nov 13, 2003 | 11:41 AM
Bigsmasher's Avatar
Re: Reset ECU?
which method should we use? THe disconnceting the battery method or the long method of pressing the gas 5 times for 5 seconds and ect ...
Old Nov 13, 2003 | 12:12 PM
GX9901's Avatar
Re: Reset ECU?
What is the purpose of the ECU reset? Is it to gain more performance? How? Does it improve or decrease gas mileage?
Thanks.
2004 Diamond Graphite/Graphite AT
Premium, Nav., 18" Wheels
Old Nov 13, 2003 | 03:00 PM
sybertel's Avatar
Re: Reset ECU?
Hi:
Thanks for all the info on the ECU re-set. Has any one actually tried this? If so, was there a measurable increase in performance?
<font color=green>6 MT ~ (DP w/ WL)</font color=green>
Old Nov 13, 2003 | 04:38 PM
Msedanman's Avatar
O.F. Administrator
Re: Reset ECU?
Bigsmasher, It's never too late to reset the ECU. Having waited so long, you may notice quite a difference in performance when you do the reset.
As far as which method to use, I don't think it matters. It seems they both work equally well. My personal preference is the quick method, but it's timing is difficult to master.
GSM
Old Nov 13, 2003 | 08:56 PM
uheenada's Avatar
Re: Reset ECU?
by your sing i assuming that you have 6MT... 6MT usually don't get as much power by resetting ECU than AT.. but i heard you still feel little better in performance... ECU reset to gain performance is really for AT drivers bcuz of adaptive tranny...(exclusive reset after you put new mod on)
Old Nov 13, 2003 | 09:13 PM
gregG35C's Avatar
Re: Reset ECU?
Thanks for DYI link. Once reset do you need to drive aggressively for it to "adapt?" Or is the power just there when you need/want it? On my bimmer the adaptive transmission read the way you were driving at that moment and adjusted to that style of driving. You guys seem to be saying to expect a power increase.
Old Nov 14, 2003 | 02:48 AM
Msedanman's Avatar
O.F. Administrator
Re: Reset ECU?
I believe that once the ECU is reset, it then adapts again quickly to your driving style. In other words if you don't drive aggressively all the time, you'll need to do a reset periodicly to get the crisp shifts back.
I don't drive a lot, and not always very aggressively, so I reset every 2 to 3 weeks.
My guess is that if you went out and drove aggressively for an hour or so, the ECU would learn that style too and resetting the ECU would be unnecessary.
GSM
Old Nov 14, 2003 | 01:37 PM
skm7's Avatar
Re: Reset ECU?
Do you need to do all procedures including Accelerator Pedal Release Position Learning , Throttle Valve Closed Position Learning , Idle Air Volume Learning (Throttle Position Learning) , or just the first part?? Sorry I don't know much about this stuff..
Thanks for your help!!
06g35
Feb 14, 2022 05:59 AM
esotericrider
V36 General Tech Questions
Mar 4, 2019 07:53 PM
MThawkins86
Oct 24, 2015 02:07 AM
vamarris
Sep 26, 2015 12:56 PM
