Service Engine Soon light...
Old Apr 27, 2009 | 10:59 PM
Doruk's Avatar
Hi everyone
i have a questions for you,
today i was waiting for my gf in the car and i push the gas pedal couple times while i was waiting, when the cars was off, then when i started the car slip,service engine soon and vdc lights all came on and the car wasnt accelerating, then i stopped and started again and it worked fine but the service engine soon light stayed on,
do you guys know if anything is wrong? how can i get rid of it? would i possibly damage, hurt something?
thank you for your input in advance
Old Apr 28, 2009 | 01:49 AM
TXaaron3232's Avatar
Ooooohhh.....thats bad my friend. You should take that to the dealership asap
im just f*ckin with ya, stop by an autozone and tell them your service engine light is on, they will plug into it and see what the computer is saying is messed up.
Old Apr 28, 2009 | 05:40 AM
infg35coupe's Avatar
may be the o2 sensor
Old Apr 28, 2009 | 09:32 AM
Doruk's Avatar
why would it happen?
so if i push the gas pedal when the car is off this will happen every time?
i have extended warranty on the car so maybe i will ask to the dealer to fix it when i go this week for an appointment to get my airbag light turned off which came on last week for no reason and they are changing crash sensor..
Old Apr 28, 2009 | 01:15 PM
man, it can be absolutely anything. Mine came on cause my gas cap wasnt on tight enough. Its as easy as stopping at an auto parts store to find out why its on, or just ask your stealership when you go there.
Old Apr 28, 2009 | 06:54 PM
superchargedg's Avatar
That is usually the sign of the the TPS switch going bat.......sounds like a new throttle body to me........im on my 3rd one.
Old Apr 29, 2009 | 11:23 AM
BloodlineG's Avatar
i would think it would be your throttle body sensor. mine did the same thing, then like 3 days later it went out. and i got towed to infiniti, it has nothing to do with you pushing the gas pedal with the car off. get it replaced under warranty.
Old Apr 29, 2009 | 03:19 PM
TurK's Avatar
why would you want to choke the car by pushing the gas pedal while the motor is not running?
Old Apr 29, 2009 | 03:43 PM
Doruk's Avatar
ahah i was just sitting in the driver seat reading stuff and had pushed the pedals without thinking like that.
bu arada turkmusun?
Old Apr 29, 2009 | 06:01 PM
thatguy II's Avatar
it's an e-throttle, if the engine's not running nothing happens.
even if it is switched "on" and not running it's injected so all the throttle body is doing is opening for the helluvit.
SiMpLyMoDiFiEd
The FX-Spot
Dec 2, 2021 04:35 PM
poker_lamina
Sep 1, 2015 09:04 AM
03sedang35
Aug 29, 2015 07:56 PM
Ivan Duben
Canada
Aug 29, 2015 12:50 AM
igking
Jul 19, 2015 01:12 AM
