Changing trunk and torx bolts?
Old Jul 13, 2009 | 05:05 PM
Foques's Avatar
Hey guys,
I want to change out a trunk. Already have a new one (thanks MasterGrade), but have a problem getting rid of my current stock one..
The torx screws are stripped (like someone used a wrong size torx bit), so I want to buy me a new set of bolts.
anyone knows what size I would be buying?
I would VERY much prefer to not be getting the torx bolts, just 10 mils or something.
any input is appreciated.
thanks.
Old Jul 14, 2009 | 09:27 AM
Foques's Avatar
anyone?
Old Jul 14, 2009 | 10:37 AM
OBG3506's Avatar
Call mastergrade and ask them what size they are or the dealer! Shoould be quick and painless, maybe!
Old Jul 14, 2009 | 12:32 PM
PPGFREAK's Avatar
You can just lift your hood and pull out one of the fender bolts out and bring it in to a hardware store and match it up. That happend to me so I just used 10mm bolts, but you can go buy torx if you want so this will happen again
Old Jul 14, 2009 | 12:33 PM
Foques's Avatar
yeah, I'd rather not use the torx bolts again
so, those are 10mm?
Old Jul 14, 2009 | 12:51 PM
painttitblak's Avatar
you actually need to use a bolt with a flat head like the torx bolts becuase if you dont the top of the head will hit on the shocks and your truck will not close.
Old Jul 14, 2009 | 01:23 PM
PPGFREAK's Avatar
^I can go take a picture of mine if you would like but I have 10mm and it closes and I know at least three other members that have the same set up.
The bolt head it 10mm, not the thread.
Old Jul 14, 2009 | 03:21 PM
Foques's Avatar
umm.. if you do go that route, could you grab an exact size of the bolt you used, please?
Old Jul 14, 2009 | 03:33 PM
1trueG's Avatar
Easy to do...Drill out the heads of the current bolts since they are stripped. After that, take the part of the screw with the threads with you and just match it up at your local hardware store. Are you running the shocks with your new trunk?
Old Feb 11, 2011 | 11:51 AM
Foques's Avatar
Ok, I need OEM stuff now.. getting rid of the car.. anyone has any for sale?
the fender screws are used elsewhere already
tal1412
Nov 28, 2022 09:25 AM
G35VSHNG37
Oct 25, 2015 08:43 PM
linedr89
Aug 17, 2015 05:11 PM
kinetek
Aug 3, 2015 04:25 PM
