Tire size question
Old May 6, 2010 | 02:34 AM
code2424's Avatar
Tire size question
Ok well I am running right now on front 235/35/19 tires and on the back 245/40/19. I am using oem rays. I just had a big nail on the rear and I patched it up but it's time to get new back tires. So I found a good deal on these tires they are size 245/45/19. Would that be good on the back? I know it's a bit taller is it going to be that noticeable though? You guys think I would be running to tall on the back? Also I don't care if it messes up my speedometer by a few miles and ****.
Old May 6, 2010 | 03:07 AM
develop1's Avatar
Infiniti engineers gave the car those specific tire sizes for a reason, that's the way it functions at its best. Stick with the original size.
Old May 6, 2010 | 12:25 PM
DOCSG35's Avatar
Why don't you bump it up to 255/40! That's what I'm running on my rear with the OEM 19's!
Old May 6, 2010 | 02:08 PM
G_JaY-SInGH's Avatar
go with 245/35 in front or 255/35 in front. and rear must be 275/35
275 looks awesome in rear
Old May 6, 2010 | 02:22 PM
Texasscout's Avatar
As long as the "rolling circumference" (revolutions per mile) is the same as stock, you can run several different sizes. My sedan stock size was 235 45 18 and I am now running 245 40 19's. The revolutions/mile is the same and my seedometer is correct, but now I run bigger wheels/tires.
You an also run even larger tires just as long as the ratio of the rolling circumferance of the (front and back) tires is the same. With a sedan, it's easy b/c all the tires are the same size. I don't know if the Coupe's tires have the same rolling circumferance front and back even though they are different sizes.
BTW: you want to maintain the same ratio so your VDC and ABS will not get confused.
Old May 6, 2010 | 03:06 PM
joek19522's Avatar
Are you running the 225 40 19 on the front?
Old May 6, 2010 | 04:40 PM
izeroi's Avatar
I have a feeling if you go with a 245/45 in the rear you're going to throw your vdc off . I'd stick with 245/40 if I were you.
Old May 6, 2010 | 06:03 PM
DOCSG35's Avatar
I have 245/35 in the front and 255/40 in the rear. I've had this setup for about a year with no issues with the VDC/ABS!
Old May 7, 2010 | 01:22 AM
Ahmad_1290's Avatar
I'm running with 245/35 up front and 275/35 in the rear on OEM rays. No issues here.
Old May 7, 2010 | 01:57 AM
code2424's Avatar
Ok thanx. I guess I will be looking for 245/40 or 255/40. Btw I always drive with vdc off if that makes a difference.
vitamin.v
Nov 7, 2019 06:10 PM
Jnm07
Aug 6, 2015 03:03 AM
reaper76
Aug 5, 2015 10:13 AM
Popes
Jul 29, 2015 05:07 PM
CrazyLogic219
Jul 23, 2015 10:58 AM
